[NEWBIE] Using Mapserver and PROJECTION
François TOURDE fr-ms at TOURDE.ORG
Sun Jun 26 10:38:28 EDT 2005
Hi the list.
I'm a newbie using mapserver, and in geodata. :( ... I've a probably
simple problem using the image output:
On my .MAP file, I have the following lines:
# Mode latlong
  EXTENT 2.8830 42.683 7.5 43.950 # Geographic
  PROJECTION "init=epsg:4326" END
  UNITS DD
All my layers have no PROJECTION infos.
When I replace the above lines by:
# mode Collignon
  EXTENT 205512.50       4889370.83 521106.75       5051672.48
  PROJECTION
   "proj=collg"
  END
  UNITS METERS
the image is ... blank. No coast lines, no features, etc...
Could you point me the problem?
Thanks in advance.
