[NEWBIE] Using Mapserver and PROJECTION
François TOURDE
fr-ms at TOURDE.ORG
Sun Jun 26 12:09:48 EDT 2005
Le 12960ième jour après Epoch,
Frank Warmerdam écrivait:
> On 6/26/05, François TOURDE <fr-ms at tourde.org> wrote:
>> Hi the list.
>> I'm a newbie using mapserver, and in geodata. :( ... I've a probably
>> simple problem using the image output:
>> On my .MAP file, I have the following lines:
>> # Mode latlong
>> EXTENT 2.8830 42.683 7.5 43.950 # Geographic
>> PROJECTION "init=epsg:4326" END
>> UNITS DD
>> All my layers have no PROJECTION infos.
>> When I replace the above lines by:
>> # mode Collignon
>> EXTENT 205512.50 4889370.83 521106.75 5051672.48
>> PROJECTION
>> "proj=collg"
>> END
>> UNITS METERS
>> the image is ... blank. No coast lines, no features, etc...
>> Could you point me the problem?
> François,
> It could be a number of things, but your bounds do seem reasonable.
> I would suggest adding an explicit ellipse definition:
> PROJECTION
> "proj=collg"
> "ellps=WGS84"
> END
I do the try... same blank image :(
> Use normal debugging techniques. For instance, check
> your error log
No errors on apache log:
[Sun Jun 26 18:06:35 2005].738511 msDrawMap(): Layer 1 (polb), 0.000s
[Sun Jun 26 18:06:35 2005].739360 msDrawMap(): Layer 2 (coast), 0.001s
[Sun Jun 26 18:06:35 2005].739597 msDrawMap(): Layer 3 (depth), 0.000s
[Sun Jun 26 18:06:35 2005].739687 msDrawMap(): Drawing Label Cache, 0.000s
[Sun Jun 26 18:06:35 2005].739715 msDrawMap() total time: 0.002s
> try rendering with shp2img, as that can provide
> better feedback.
Probably, but it gives me a SEGFAULT on my Debian... I will try a
strace... later :)
> Turn on debugging.
Already turned on.
Many thanks for your response.
