polygon points from shapefile
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue Jun 28 12:59:32 EDT 2005
joerg p wrote:
> thanks, I am gonna learn it.
> But is this the only possibility? Isn't there a 'usual' phpmapscript
> command?
Yes, you can do it via mapscript. Sorry, I don't have the code for it,
but you might check the wiki. Also look at the perl mapscript examples,
they can be ported to php without much trouble.
-Steve W.
> Joerg
> Till Adams schrieb:
>> joerg p wrote:
>>> hello,
>>> is it possible, to get the points of a polygon from a shapefile in an
>>> array via phpmapscript?
>>> So that I get e.g. ((49.12390,5.283990),(49,238238,5,23423442),....)
>>> thanks
>>> Joerg
>> Joerg,
>> why not using Mapserver as WFs Server? with the getFeature request
>> you'll get the data as GML.
>> Get more info on that topic on:
>> http://ms.gis.umn.edu/docs/howto/wfs_server
>> Cheers, Till
