Antwort: Re: [UMN_MAPSERVER-USERS] Bug in msCopy
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Wed Jun 29 06:10:03 EDT 2005
On 6/29/05, Benedikt Rothe <umn-ms at hydrotec.de> wrote:
> Hello Umberto
> Thank you for yout hint's!
> You are right: One should be cautios. But for the moment I have the
> impression
> that we seeme to have found a way, which don't raise obvious errors in the
> first
> moment :-)
> After the mentioned changes in mapcopy.c the approache
> (TomCat/MapScript/Connection-Pooling/MapCloning) seeme to
> work for us. (Working with Version 4.6)
> But:
> - We do need some more stress-testing.(We already made automated
>   http-requests from a Java-Programs. But this was definitly not enough and
>   not "nasty" enough!)
jmeter is an excellent tool for stress/load testing (
jakarta.apache.org/jmeter/ )
> - New problems could raise, if more or other features from
> mapserver/mapscript
>   are used then we actualy do.
> - Memory footprint of the running-tomcat has to be watched!. What about the
> size
>    of the application after 100, 500, 600, 800 ... requests? (I'm not quite
> shure how to do this!
Use the -Xloggc:/tmp/gc.log to java when starting tomcat and then run
the stress tests. You should be able to see that if memory get
correctly garbage collected the avail mem is almost always equal to a
certain initial size.
Warning: this is not 100% error proof, but it should be start. try googling...
Ciao,
Umberto
>    Watching Java-Programs is difficult because of garbage-collections ...)
> Greetings
> Benedikt
> Umberto Nicoletti <umberto.nicoletti at gmail.com> schrieb am 29.06.2005
> 11:03:46:
>  > > Dear List
>  > > We are using MapScript/Tomcat/Java/OracleSpatial.
>  > > We use mapObj.mapClone() to get a fresh mapObject
>  > > in each request without reading the Mapfile.
>  > Benedikt,
>  > I would not do that (tm). In my apps I recreate a fresh mapObj with
>  > each request  as the overhead is mininum and the benefits high (so
>  > that the ratio is in favor of this approach).
>  > Besides this is the only known method to work (as far as I know) and
>  > this stems from the fact that mapserver was in the beginning (and
>  > still is, with improvements) a CGI. As you might know cgis are
>  > processes that are created by the web server to serve a single request
>  > and then exit, so memory cleanup and thread safety are non-issues for
>  > them.
>  > Even in php mapscript php must be used as a cgi (instead of a DSO) to
>  > make sure that it works.
>  > > We detected problems after we activated Connection-Pooling:
>  > > Tomcat crashed in mapObj.delete()
>  > I would not use connection pooling just because it will not work
>  > reliably with Java Servlets for the reasons explained above.
>  > This matter (connection pooling and map cloning) surely requires
>  > deeper investigation, one of the developers coul step in to give his
>  > opinion on my statements (which I would sincerely hope were false, but
>  > fear not). Btw, I seem to recall that the above issues (long lived
>  > instance against per request instance)  were already discussed on the
>  > list before.
>  > Best regards,
>  > Umberto
>  > > Hole thing turned out to be a bug in mapcopy.c where
>  > > the joins are copied:
>  > > MS_COPYSTELEM(numjoins);
>  > > for (i = 0; i < dst->numprocessing; i++) {
>  > >    return_value = msCopyJoin(&(dst->joins[i]), &(src->joins[i]));
>  > > This must be changed to
>  > > for (i = 0; i < dst->numjoins; i++) {
>  > > There is some other code in mapobject.c, wich didn't
>  > > raise any problems for us, but from wich I do think
>  > > that array-allocs are missing.
>  > > I watched the code an *think* these are are not allocated
>  > > anywhere. I hope, there is no misleading hint:
>  > >  // I do think, that dst->point is not allocated.
>  > >  // code seems to be unused (?)
>  > >  dst->numpoints = src->numpoints;
>  > >  for (i = 0; i < dst->numpoints; i++) {
>  > >   MS_COPYPOINT(&(dst->point[i]), &(src->point[i]));
>  > >  // I do think, that dst->items and dst->values is
>  > >  // not allocated
>  > >  MS_COPYSTELEM(numitems);
>  > >  for (i = 0; i < dst->numitems; i++) {
>  > >   MS_COPYSTRING(dst->items[i], src->items[i]);
>  > >   MS_COPYSTRING(dst->values[i], src->values[i]);
>  > >  // I'm quite shure, that dst->items is not allocated
>  > > I hope this is helpful. Greetings
>  > > Benedikt Rothe
