get part of very large raster
Frank Warmerdam
fwarmerdam at GMAIL.COM
Wed Mar 2 09:36:29 EST 2005
On Wed, 2 Mar 2005 10:11:24 +0100, Ivan Mjartan <ivan.mjartan at geovap.cz> wrote:
> Hi, everybody
> I have little problem,
> I have very large raster over 100M, and I have to programming small program,
> that on input get Xmin, Xmax, Ymin, Ymax and return small wedge of this
> large raster.
Ivan,
Hmm, 100M is large? It depends on context I suppose.
> My first test was using GD library but problem is that this library load
> whole raster into memory and its mean, that its take very long time.
> I know (I am developing something on mapserver), that mapserver is doing
> this and very fast and my question is, which library mapserver is using , or
> which part of code is processing this ?
As Bart mentioned, GDAL attempts to provide efficient access to
subregions (and reduced resolutions) of raster files and is used as
the basis of most raster input for rendering in mapserver.
I would add that the organization of the data also plays a role in
efficiency. If you want to be able to extract subwindows from
a dataset with maximum efficiency it is helpful to ensure the raster
is tiled. That is internally the image is stored as a bunch of smallish
tiles so that pulling a local area out is just matter of accessing the
corresponding tiles. In a normal "scanline oriented image", picking
out a subwindow generally results in paging in the entire scanlines
touched by the subwindow which is pretty inefficient.
If you have a TIFF file that is not tiled, you can convert it to tiled
format with a command like:
gdal_translate -co TILED=YES in.tif out.tif
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
