A confused Network Admin
Lisi, Christine lisi at MYDELRAYBEACH.COM
Wed Mar 2 12:35:55 EST 2005
It is actually not very complicated.  You're using trying to start using
a LOT of different technologies all at once.  Most people don't do that,
so that's why relatively few people can be expected to be as frustrated
as you are <g>.  YOU'RE RIGHT.
For example, MapScript is a PHP module.  Most users who want to start
using PHP MapScript are PHP users who would like some maps.  If you were
a PHP user and familiar with PHP and modules, most of your recent email
conversations would be straightforward and obvious.  It's perfectly OK
that you are new to all that, but don't blame MapScript.  It's not being
complicated - it's pretty straightforward.  You'd be having the same
problems with ANY external PHP module.  I was not blaming MapScript at
all.  My frustration is with Open Source software in general and trying
to get all the pieces to work together.
I'll remind you of my first email to you.  MapScript is NOT a "MapServer
module".  There is a large library of mapmaking functionality in the
MapServer suite.  All that code (think of it as a small collection of
related DLLs) has been wrapped into several interfaces.  One of those is
the MapServer CGI program, which allows CGI requests to be made against
the libraries, and one is the PHP MapScript module, which lets PHP
scripts call functions in the libraries.  They are completely
independent of each other - neither one requires the other.  Some users
use both, and your consultant seems to want to do that.  But they are
two separate things.  You do not need to have MapScript installed to use
the MapServer CGI.  My confusion with thinking that MapScript is a
MapServer module comes from the README.txt distributed with MapScript.
On the very top it says PHP/MapScript Mapserver Module.  This would
confuse any beginner like me.  Thanks for the clarification.  I'm sure
the consultant will know what to do with it all.  My part of the job is
almost complete.
You should go back to the error message you reported from your working
PHP script.  As was mentioned, your script cannot load a module from a
file that is evidently there.  That means that (a) the script doesn't
have permission to load that module or (b) that module has dependencies
it cannot find.  As stated in one of my earlier messages, the problem
was that I didn't have the MapScript version (4.5) for PHP 5.0.3.  It
seems that although PHP 5.0.3 is a functional/tested version, the
MapScript version for PHP 5.0.3 is still in "beta".  Nobody's fault, but
I refer back to my frustration with Open Source software in general.
Don't get me wrong - thank goodness for Open Source and I give kudos to
the programmers, but for an admin like myself it can be very frustrating
and time consuming to get it all together.  Once I downloaded the
correct MapScript module for PHP 5.0.3 everything worked, but I am still
confused at to why a newer version of MapScript (4.5) would have older
.dll's than an older version (4.4).  Maybe I'm spoiled because I'm so
used to being able to call up Tech Support and get issues resolved and
questions answered.  Verbal communication is much more effective than
e-mail in communicating these complicated issues.  I'm dealing (with
it)...
The first place I'd look is whether the C:\PHP directory is on the
search path of the user context running in IIS (usually the
IUSR_<machinename> account).  You can probably just add that directory
to the system search path, although you should probably restart IIS
after doing that (or at least unload the site you're testing).  This is
no longer a problem.
Ed - I appreciate your input and I'm glad you appreciate where I'm
coming from.  Maybe one day I'll understand how it all works, but right
now I'm just glad to have gotten this far.  My only remaining issue is
with MapSURFER.  Can't get a response from Russ.
Christine
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Lisi, Christine
Sent: Wednesday, March 02, 2005 11:51 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] A confused Network Admin
The consultant told me to have both so I don't understand.  MapScript is
a MapServer module, no?
Christine Lisi
Application Specialist
Management Information Systems * City of Delray Beach * 100 NW First
Avenue, Delray Beach, FL 33444
Phone, 561-243-7142 * Fax, 561-243-7166 * eMail, Lisi at MyDelrayBeach.com
From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
Sent: Wednesday, March 02, 2005 11:44 AM
To: Lisi, Christine
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Christine,
you don't (normally) need both MapServer and MapScript ... you would use
one or the other.  And the versions wouldn't have to match (except
perhaps for dependencies).
MapScript is completely self-contained ...
Paul
Lisi, Christine wrote:
> OK, Paul's script now works and returns no errors - also sees
MapScript.
> The way I accomplished this was that I downloaded PHP MapScript
version
> 4.5 for PHP 5.0.3 (thank you Yewondwossen!).  It says it's compatible
> with MapServer 4.5, but I can't find that version on the MapServer
site.
> The latest listed is 4.4.1.  Why oh why does this all have to be so
> complicated?!  Does anyone know where I can download MapServer 4.5?
> My other concern is that many of the .dll files in this MapScript 4.5
> version are older than those in MapServer.  I did replace the
gdal12.dll
> in MapServer with the version 1.2.5 from MapScript 4.5 because it
states
> in the README.txt that MapScript requires this version.  I hope this
> doesn't mess things up in the long run.
> Is anyone else as frustrated as I am?
> Christine Lisi
On
> Behalf Of Paul Spencer
> Sent: Wednesday, March 02, 2005 9:15 AM
> slight clarification, the php module name is case sensitive and for
> mapscript it is actually "MapScript".
> For the record, my test script for testing MapScript extension is a
> little simpler :)
> <?php
> if (!extension_loaded('MapScript'))
>      dl('php_mapscript_44.'.PHP_SHLIB_SUFFIX);
> phpinfo();
> Also, for most purposes, it is more convenient to make a copy of
> php_mapscript_44.dll and name it php_mapscript.dll, then your scripts
> can all reference php_mapscript.dll as the most recent version.  When
> 4.6 comes out, you can test your apps then upgrade everything by
making
> php_mapscript.dll a copy of php_mapscript_46.dll
> Cheers
> Paul
> William Bronsema wrote:
>>Also note that the extension_loaded check is not the extension_name
>>(i.e. php_mapscript_44) rather it is the module name itself. In this
>>case it is "mapscript".  Your code should be:
>>if(!extension_loaded('mapscript'))
>>HTH,
>>Bill
>>________________________________________________
>>William A. Bronsema, C.E.T.
>>Applications and Software Development,
>>DM Solutions Group Inc.
>>*From:* UMN MapServer Users List
>>*On Behalf Of *Jeff Portwine
>>*Sent:* March 2, 2005 8:19 AM
>>*To:* MAPSERVER-USERS at LISTS.UMN.EDU
>>*Subject:* Re: [UMN_MAPSERVER-USERS] A confused Network Admin
>>Make sure that you have the <?PHP  line in front of everything and
> that
>>the script is ended with ?>.
>>I think in the original example he just had <?  which should be ok,
> but
>>I like to use <?PHP myself.  It looks like your script omitted the
>>so it wasn't being recognized as a php script and was just reading the
>>script as though it were html and outputting the text to your browser.
>>Hope this helps,
>>Jeff
> |Paul Spencer                           pspencer at dmsolutions.ca   |
> |Applications & Software Development                              |
> |DM Solutions Group Inc                 http://www.dmsolutions.ca/|
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050302/cf69f0e0/attachment.html
