msOracleSpatialLayerGetShape(): Function not implemented yet
Bart van den Eijnden bartvde at XS4ALL.NL
Fri Mar 4 04:07:52 EST 2005
Which Mapserver version are you using? Are you sure your Mapserver is
compiled with native Oracle Spatial support (INPUT=ORACLESPATIAL)?
The function is implemented for sure in the last release version (4.4.1).
Best regards,
Bart
> i've been trying to query an image box. when i use shapefiles the
> querybyrect function works fine. when i try using the same on oracle 9i i
> get the following error.
> "msOracleSpatialLayerGetShape(): Function not implemented yet "
> am connecting using "CONNECTIONTYPE oraclespatial". How soon will the
> function be implemented. i got some information that i have to use OGR.
> but
> i don't want to recompile the whole shebhang again. Is there a work around
> to this problem
