.map and .tab files
Jose Luis Gonzalez
joseluismapserver at YAHOO.ES
Wed Mar 9 05:59:31 EST 2005
Hi Brent and all the rest.
I have resolved the problem just as I told you, thanks to your solution, but I have a problem related to it, and I do not know how to solve it.
In the begining I only was using one map, so I included the .tfw file manually en th WEB-INF directory and that was all. But now I use many maps, and I have to include the correct .tfw file depending on the map I use.
So is there any mapserver instruction so I can associate the .tfw to the mapObj I am generating? Or what is the way of doing it?
Thank you to all
Jose Luis
P.D. I am using Linux, and Mapserver 4.4.1
Brent Fraser <bfraser at GEOANALYTIC.COM> wrote:
For a world file description, have a look at:
http://lists.umn.edu/cgi-bin/wa?A2=ind0501&L=mapserver-users&P=R31342&I=-3&X=5DD2E75F03DF29CF75
Sorry about the ellps info (it's not Clark 1866). Your tab file shows 1001
as the datum code. From the MapInfo doc, this indicates a datum of Pulkovo
1942, which uses the the Krassovsky ellipsoid. Your PROJECTION object
should include the Proj4 keyword of "ellps=krass"
Brent
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Monday, January 31, 2005 8:52 AM
Subject: Re: [UMN_MAPSERVER-USERS] .map and .tab files
Sorry but I don't undersand what to do in point number 1.
How can I do a .tfw file? How does it look like?
and respect to point 3: how do you know which is the ellps parameter?
Thanks
Jose Luis
Brent Fraser wrote:
Jose Luis,
Three possibilities:
1. The tiff might be a plain tiff, not a GeoTiff (with registration info
attached as a TIFF tag). Make a .tfw georeferencing "world" file for it
using the information in the TAB file
2. You may have your false_easting and false_northing values swapped in the
PROJECTION object of your map file. Double check with the CoordSys
statement in t he TAB file.
3. No ellipse is given in the PROJECTION object. Add "ellps=clrk66"
Since your output projection is the same as your input projection, you could
just remove the two PROJECTION objects in your map file. You would stillneed
to make a world file for the tiff file.
Brent Fraser
Sent: Monday, January 31, 2005 8:19 AM
Subject: [UMN_MAPSERVER-USERS] .map and .tab files
Hi everyone
I can not manage to draw a raster I have.
This raster is a .tiff file that has associated this .tab file:
!table
!version 300
!charset WindowsLatin2
Definition T able
File "praha.tif"
Type "RASTER"
(3445375,5560000) (0,0) Label "Pt 1",
(3474000,5560000) (4507,0) Label "Pt 2",
(3474000,5539250) (4507,3266) Label "Pt 3"
CoordSys Earth Projection 8, 1001, "m", 15, 0, 1, 3500000, 0
Units "m"
RasterStyle 7 0
When I put this data to the .map file I write it as:
MAP
NAME praha
STATUS ON
IMAGETYPE PNG
SIZE 800 500
SHAPEPATH
"/opt/SUNappserver/domains/domain1/applications/j2ee-modules/test8"
EXTENT 3445375 5539 250 3474000 5560000
UNITS METERS
PROJECTION "proj=tmerc" "lat_0=0" "lon_0=15" "k=1" 'x_0=0" "y_0=3500000"
END
WEB
IMAGEPATH "/opt/SUNappserver
/domains/domain1/applications/j2ee-modules/test8/"
IMAGEURL "/test8/"
END
LAYER
NAME "Nighttime lights"
TYPE RASTER
STATUS ON
DATA
"/opt/SUNappserver/domains/domain1/applications/j2ee-modules/test8/praha.tif
END
END
END
Am I doing it correctly?
Am I missing anything?
Thank you
Jose Luis
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050309/1173f885/attachment.html
