inline feature
Dirk-Jan Huisman d.huisman at INGBCC.NL
Thu Mar 10 08:27:25 EST 2005
My LAYER is:
	LAYER
	     NAME "credits"
	     STATUS DEFAULT
	     TRANSFORM FALSE
	     TYPE ANNOTATION
	     FEATURE
	             POINTS
	                     300 300
	             END
	             TEXT 'Hello world.'
	     END
	     CLASS
	             LABEL
	                     TYPE BITMAP
	                     COLOR 0 0 0
	             END
	     END
	END
The LAYER in the link below gives the same problem.
best regards,
did you try something like described in:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0103/msg00026.h
tml
Can you provide more info? The LAYER from your MAP file will help
analyzing the problem.
Best regards,
Bart
> Hi all,
> I want to draw text (copyright) in my map. In my mapfile I put the
code
> (FEATURE keyword). The string is drawed once and it looks good. But
> after zooming it's gone.
> What to do to draw the text again after each request?
> Dirk Jan
Prins Mauritsstraat 17, Postbus 75, 4140 AB Leerdam
Telefoon (0345) 63 96 96, Fax (0345) 63 96 66,
E-mail post at ingbcc.nl
Internet www.ingbcc.nl
Deze e-mail en de eventuele bestanden die meegezonden zijn, zijn vertrouwelijk en alleen bedoeld voor het gebruik door de individu of instelling aan wie deze e-mail geadresseerd is. Als u deze e-mail onterecht ontvangen heeft wilt u het ons dan laten weten.
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the system manager.
