Projection
Frank Warmerdam
fwarmerdam at GMAIL.COM
Thu Mar 10 10:20:08 EST 2005
On Thu, 10 Mar 2005 16:08:55 +0100, Dirk-Jan Huisman
<d.huisman at ingbcc.nl> wrote:
> Hi all,
> My projection(British_National_Grid) file should be something like this:
> PROJECTION
> "proj=tmerc"
> "lat_0=49"
> "lon_0=-2"
> "x_0=400000"
> "y_0=-100000"
> "k=0.999601272"
> "ellps=Airy_1830"
> "datum=D_OSGB_1936"
> "to_meter=1"
> "no_defs
> END
> I'm using Windows2000 and Apache.
> With the install of Mapserver I copy proj/nad to C:\
> I have an unknown elliptical parameter ("ellps=Airy_1830") and unknown
> datum parameter("datum=D_OSGB_1936").
Dirk-Jan,
You can use the command "cs2cs -ld" to list available
datum names. D_OSGB_1936 is not amoung them.
In fact, I don't know a good approximation to use for
the OSGB 1936 to WGS84 transformation. If you have
a preferred 3 or 7 parameter transform you would like
to use, then provide it via the +towgs84 parameter.
Otherwise just drop the datum identfier and stick to
operating on the OSGB 1936 datum.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
