layer type circle
Bart van den Eijnden
bartvde at XS4ALL.NL
Fri Mar 11 06:35:43 EST 2005
Hi Nicol,
AFAIK inline features are in pixel coordinates, not in world coordinates.
I don't know how to create a buffer in real world coordinates with
Mapserver though, so that doesn't help you ...
Best regards,
Bart
> Hi List,
> i would like to use the layer type 'circle'. Attached you find the
> mapfile i use. I expect to get a circle whose diameter is determined by
> the two vertices of my line (bounding box for the circle).
> What i get is as single point (1x1 pixel) in the center of the two
> points.
> Do i have a wrong understanding of the layer type, do i miss something
> or is this a bug?
> Many thanks for your help
> Nicol
> MAP
> NAME Germany
> EXTENT 5.86628568 47.27360151 15.0486318 55.05826185
> SIZE 300 300
> UNITS DD
> WEB
> IMAGEURL "/~nicol/mapserver/phpmapserver/tmp/"
> IMAGEPATH "/home/nicol/public_html/mapserver/phpmapserver/tmp/"
> END
> LAYER
> NAME "buffer"
> STATUS DEFAULT
> TYPE circle
> #TYPE line
> FEATURE
> POINTS
> 8.2588482 48.87774279
> 8.2588482 49.1577759
> END
> TEXT "circle"
> END
> TEMPLATE "dummy.html"
> CLASS
> NAME germany
> COLOR 0 0 255
> OUTLINECOLOR 0 0 0
> LABEL
> TYPE bitmap
> SIZE small
> END
> END
> END
> END
