LabelAngleItem question
Eric Bridger eric at GOMOOS.ORG
Fri Mar 11 09:27:18 EST 2005
On Fri, 2005-03-11 at 03:21, Stéphane RIFF wrote:
> Can someone show me an example because
> i don't know how to do it.
> I can create dynamic layer but the problem
> is how to set orientation for each points, i don't think
> a class for each orientation is a good solution
> but i don't see anything else.
You are not providing enough details about what you are trying to do.
Where are your points? Shapefile, PostGIS, etc.
Are you using CGI Mapserver or Mapscript?
If I understand correctly the only issue is that your angles need to be
mulitplied by -1. The easiest way is to create a new column in your
datasource which is negative of you existing angles. And use the new
column as your LABELANGLEITEM.
