Mapserver Usage
Bart van den Eijnden
bartvde at XS4ALL.NL
Sun Mar 13 03:47:54 EST 2005
Hi Giridhar,
check out the following:
Building MapServer Applications with PostGIS - Paul Ramsey & Chris Hodgson
http://www.omsug.ca/dl/osgis2004/PostGIS-ms.ppt
http://www.omsug.ca/dl/osgis2004/PostGIS-Mapserver.doc
http://www.omsug.ca/dl/osgis2004/postgis-ms.zip
That should help you getting started.
Best regards,
Bart
On Sat, 12 Mar 2005 21:53:31 -0600, Giridhar Manepalli
<gmanepal at GMAIL.COM> wrote:
> Hello All,
> I am working on a project in which one of the application produces some
> information viz., location of agents, each agents characteristics(age,
> health etc) into a database(PostGresql). The location of agents is in the
> form of
> PostGIS Supportive Spatial Data format. The agents produced by the
> application belong to a area whose shapefile is available.
> I appreciate a lot if someone can throw some light on the following:-
> How can I dynamically produce a map using mapserver, so that I can grab
> the
> agent data from the Database and display it(This includes the agent
> characterisitics as mentioned above)?
> It would be helpful to me, if you can point out some general/specific
> guidelines for achieving the same. Also, a pointers to similar
> applications,
> especially one which integrates querying on agent characteristics, if I
> am
> not asking too much.
> Thanks,
> Giridhar
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
