Raster Layers
Ed McNierney ed at TOPOZONE.COM
Mon Mar 14 09:34:28 EST 2005
JC -
Not common, but you should rebuild MapServer WITHOUT "INPUT=TIFF"
support.  I'm assuming your rasters are TIFF images, and the GDAL
library provides much better support for TIFF than the former standalone
TIFF library.  If I recall correctly, I think the default configuration
does not include INPUT=TIFF support, so you may have added it when you
configured MapServer.  Reconfigure it without TIFF support and you'll
let GDAL provide TIFF support.
If you still have trouble, please provide more details about the image
you're using and how you're using it.  Thanks!
     - Ed
Ed McNierney
TopoZone.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of James Cradock
Sent: Monday, March 14, 2005 8:50 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Raster Layers
I've installed MapServer 4.4.1, and shapefiles are rendering well, but
raster layers are not. This is on Debian, and GDAL was installed from
APT. (MapServer is *not* in APT.) Info:
./mapserv -v
MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
INPUT=TIFF INPUT=EPPL7 INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
The GDAL utilities (gdalinfo, gdal_translate) appear to work fine --
I'm just not getting rasters from MapServer.
Common problem?
JC
James Cradock, jcradock at me3.com
