Controlling classitems through PHP? (Tanzanian protected areas)
Ragnvald
ragnvald at MINDLAND.COM
Thu Mar 17 04:01:47 EST 2005
I have a layer of Tanzanian protected areas (National parks, Game Reserves,
Conservation areas, etc). My goal is to be able to control the visual
appearances of the separate parks based on numerical data in an animal
survey database using PHP.
I am really struggling with this and have not been able to figure it out. I
have done several searches, and to be honest working with classes through
PHP is a bit new to me. If I manage to do this it will be VERY helpful for
us here at TAWIRI.
The planned script should generate different maps for different estimated
species concentrations in these protected areas. The first step is to be
able to control the different parks appearances by referring to their names.
(Currently the developed solution will only be for testing purposes and
internal use at my department.)
This is what I can do by using a simple map-file:
http://www.mindland.com/test/tanzania_parks_pres_1.gif
The code for the "Parks" layer is like this:
LAYER
NAME "Parks"
TYPE POLYGON
STATUS ON
DATA "TZ_PAs_2002_Poly"
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=NAD83"
END
CLASSITEM 'NAME'
CLASS
COLOR 190 190 190
SYMBOL 0
EXPRESSION "Serengeti"
NAME "Serengeti"
END
CLASS
COLOR 210 210 210
SYMBOL 0
EXPRESSION "Ikorongo"
NAME "Ikorongo"
END
CLASS
COLOR 220 220 220
SYMBOL 0
EXPRESSION "Grumeti"
NAME "Grumeti"
END
CLASS
COLOR 220 220 220
SYMBOL 0
EXPRESSION "Masawa"
NAME "Masawa"
END
CLASS
COLOR 220 220 220
SYMBOL 0
EXPRESSION "Ngorongoro"
NAME "Ngorogoro"
END
END
END
The question is then how to control the CLASSITEM color appearance and also
selection of which classitems to show - through PHP. In the end I will use
database queries, but for now I will be happy to do this by hard coding it
in PHP. I am able to do changes on the other parks (not displayed as
classitems). This code is added before the map is drawn:
$layerObj = $map->getlayerbyname("Parks");
$class = ms_newClassObj($layerObj);
$style = ms_newStyleObj($class);
$style->color->setRGB(200,200,0);
Resulting image is then:
http://www.mindland.com/test/tanzania_parks_pres_2.gif
Suggestions and references to relevant postings would be fine. I re
Ragnvald Larsen
Geographer / data systems developer
Conservation Information and Monitoring Unit,
Tanzania Wildlife Researc Institute,
Tanzania
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050317/7a1262ae/attachment.html
