Application Data
Frank Warmerdam
fwarmerdam at GMAIL.COM
Thu Mar 17 17:52:02 EST 2005
On Thu, 17 Mar 2005 17:41:24 -0500, Giridhar Manepalli
<gmanepal at gmail.com> wrote:
> I would like to know, if it is possible to convert data produced from
> a third party application to a shapefile or PostGIS table.
> Hypothetically speaking, the data from the third party application
> will be in the following format.
> SSN, Lat, Long, Age etc
> Imagine that the above data is huge (as large as 100GB), so I need to
> dump this information to a database.
> I would like to know, how to use this data from a table to Map it onto
> a MAPServer.
> and process queries like:
> *.) How many people are at a given location
Giridhar,
It is certainly possible in principle to translate this data to PostGIS
or into a point shapefile, but if it is 100GB of data in that
compact comma seperated value format, it is going to be alot
larger in PostGIS or in a shapefile.
A traditional approach to handling this sort of dataset, if you
only need summary information is to aggregate it somehow.
Otherwise you are going to have alot of performance and
query optimization issues.
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
