Mark center of map?
Richard A. Milewski ram at RAMPAGE.NET
Thu Mar 17 21:02:56 EST 2005
Ryan, Adam wrote:
>>-----Original Message-----
>>From: Richard A. Milewski [mailto:ram at RAMPAGE.NET]
>>Sent: Thursday, March 17, 2005 3:43 PM
>>To: MAPSERVER-USERS at LISTS.UMN.EDU
>>Subject: Re: [UMN_MAPSERVER-USERS] Mark center of map?
>>Jeff,
>>I tried your suggestion and got it to work, but I noticed
>>some odd things and I just want to be sure I really
>>understand what I'm doing.
>>Here's the layer that works for me:
>>LAYER
>>   NAME MapPin
>>   STATUS ON
>>   TYPE Point
>>   TRANSFORM FALSE
>>   FEATURE
>>     POINTS
>>       150 150
>>     END
>>   END
>>   CLASS
>>     SYMBOL "Symbols/Airport01.gif"
>>     OUTLINECOLOR 255 255 255
>>   END
>>END
>>The unexpected things I found were:
>>1 - I seem to need either a COLOR or OUTLINECOLOR statement
>>in the CLASS clause.  It doesn't matter what color I specify
>>or whether I use COLOR or OUTLINECOLOR, but without one of
>>the two, the symbol doesn't appear.  The specified color has
>>no effect on the displayed color of the .gif however.
>>2 - The path to the marker specified in the SYMBOL statement
>>is a path relative to the .map file directory.  There is a
>>SHAPEPATH statement in the MAP object definition, but that
>>has no apparant effect here.
>>3 - It appears that the symbol is centered on the point
>>defined in the FEATURE clause.  This is really cool and makes
>>things much easier, but came as a surprise.  I was prepared
>>to calculate my own centering a la netpbm and  image magick.
>>This is much easier.
>>I now need to figure out how to change the POINT location on
>>the fly because I don't know what the actual map size is
>>until the maprequest comes in from the user. (These maps are
>>being served to phones and different phones have different
>>size screens).  The note at the end of the MapServer CGI
>>Reference seems to have enough information about how to do
>>that though.  I'll give it a try.
>>I suspect you already know everything I've mentioned here,
>>but I wanted to make sure it got into the thread in the
>>MapServer-Users list archive.  I've learned at least half of
>>what I know about MapServer from the list, and want to leave
>>as much information around for the next guy as I can.
>>Many thanks for all the help!
>>-- Richard
>Richard,
>Try leaving the feature object out of your mappin layer in the map file and
>add it to your cgi request instead.  That way you can set both the size of
>the map and the position of the icon.
>...mapserv.exe?map=yourMap.map&mapsize=300 300&map_MapPin_feature_points=150
>150&...
>Cheers,
>Adam
Adam,
Thanks for the help.  That worked.  However it created another
conundrum.  ...but being a bear of very little brain, I'm easily befuddled.
Specifying the Feature/Points clause in the url  ONLY works if I remove
it from the layer specification in the .map file.    So the question is
how do I know which parameters I can specify in BOTH places (such as the
extent, where the spec in the url overrides the one in the .map file),
and the ones like the Feature/Points spec where it can only be in one place?
-- Richard
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050317/da8985bf/attachment.html
