Is it possible : Change color on database field
Stéphane RIFF stephane.riff at CERENE.FR
Fri Mar 18 10:16:56 EST 2005
Thanks for answer,
That's not exactly what i want.
I want to change the color after each stop :
  one path                      stop         another path
stop             another path
Is that possible with a field in db that specify that a stop has
hapenned ???
Thanks
Stephen Woodbridge wrote:
> Use a and EXPRESSION ([SPEED] < 0.5) or whatever you want to consider
> as stopped in your CLASS and color it stopped, Follow this with a
> CLASS with no EXPRESSION to be the default case and color it moving.
> -Steve
> Stéphane RIFF wrote:
>> What i want to do is :
>>  I represent gps track on a map, this work fine with one class and one
>> color.
>> I want mapserver to change the symbol color each time ths vehicles stop
>> and start again
>> in the database it's a field that match speed. So each time the speed
>> field is equal to zero
>> i want to change the color.
>> I don't know how to do that , is it possible ??? How ???
>> Hope i'm understandable
>> Thanks
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050318/be6f2221/attachment.html
