crash on QueryByRect/QueryByAttr on Oracle Layer (mapserver
compiled by me)
Francesco Sozzi
fsozzi at INTERCAD.CH
Mon Mar 21 06:06:44 EST 2005
Hi Bart,
Wow, compiling with VC7 instead of VC6 it seems working fine! Thanks for
suggestion.
Now I will do further tests, but I think it's all right now.
Best regards
Francesco
----- Original Message -----
From: "Bart van den Eijnden" <bartvde at xs4all.nl>
To: "Francesco Sozzi" <fsozzi at intercad.ch>; <MAPSERVER-USERS at lists.umn.edu>
Sent: Friday, March 18, 2005 5:55 PM
Subject: Re: [UMN_MAPSERVER-USERS] crash on QueryByRect/QueryByAttr on
Oracle Layer (mapserver compiled by me)
> Hi Francesco,
>> Another sympton: I have no problem if on DATA attribute I list only key
>> and geometry fields. If I list some other fields, mapserver (compiled by
>> me) crashes.
> I had the same problem. When I recompiled with VC7.1 instead of VC6
> everything worked fine. Which MSVC version are you using?
> Best regards,
> Bart
> On Fri, 18 Mar 2005 16:28:41 +0100, Francesco Sozzi <fsozzi at INTERCAD.CH>
> wrote:
>> Hi all,
>> If I use precompiled binaries for Win32/Oracle I have no problem.
>> If I try to compile myself everything still works properly (I can
>> render, zoom, pan, querying, ecc...), but if I query (es. QueryByRect)
>> Oracle Spatial layer, mapserver crashes.
>> me) crashes.
>> There is something on how I compiled my binaries.
>> Anybody has already experimented the same problem?...
>> Bets regards
>> Francesco
> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
