PostGIS 1.0.0-rc2 points not rendering
Paul Ramsey
pramsey at REFRACTIONS.NET
Mon Mar 21 23:24:19 EST 2005
Ken,
You'll want to move to RC4, there was a problem w/ mapserver in early
releases of postgis 1.0.
Paul
On 21-Mar-05, at 7:16 PM, Ken-ichi wrote:
> Hi all. Forgive me if this has been dealt with before but I wasn't able
> to find anything. I'm having trouble rendering a point layer from
> PostGIS in MapServer. The points in the table were entered via SQL
> using the GeometryFromText() function, using a custom projection that I
> entered into the spatial_ref_sys table. Adding the points does not
> generate any errors, and when I select the rows in psql using the
> AsText() function, they look fine. However, they do not render in
> MapServer (nor do they render in QGIS, for that matter). There are no
> errors, just no points. I can dump the points out into a shapefile
> using pgsql2shp and they show up fine. I'm fairly sure this setup
> worked in PostgreSQL 7.x and PostGIS < 1.0. Here are the details of my
> setup:
> Mac OS X
> MapServer 4.4.1
> Postgresql 8.0.1
> PostGIS 1.0.0-rc2
> CUSTOM PROJECTION
> srid: 1000
> auth_name: CA_Albers
> srtext:
> PROJCS["CA_Albers",GEOGCS["GCS_North_American_1927",DATUM["D_North_Amer
> i
> can_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982]],PRIMEM["Greenw
> i
> ch",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Albers"],PARAME
> T
> ER["False_Easting",0.0],PARAMETER["False_Northing",
> -4000000.0],PARAMETER["Central_Meridian",
> -120.0],PARAMETER["Standard_Parallel_1",34.0],PARAMETER["Standard_Paral
> l
> el_2",40.5],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
> proj4text: +proj=aea +ellps=clrk66 +datum=NAD27 +lon_0=-120 +lat_1=34
> +lat_2=40.5 +x_0=0 +y_0=-4000000 +units=m
> SQL
> insert into test_points (name, comment, the_geom, error) values
> ('name', 'comment', GeometryFromText('POINT(-211189.484375
> -23160.20625)', 1000), 30);
> MAPFILE
> MAP
> NAME "blah"
> EXTENT -293050 -120300 -103350 71250
> SIZE 500 500
> SHAPEPATH "data"
> SYMBOLSET "../../tutorial/etc/symbols.sym"
> FONTSET "../../tutorial/etc/fonts.txt"
> IMAGETYPE PNG
> UNITS METERS
> WEB
> IMAGEPATH "/web/tmp/"
> IMAGEURL "/tmp/"
> END
> LAYER
> NAME "Counties"
> STATUS DEFAULT
> TYPE POLYGON
> DATA "counties"
> CLASS
> NAME "Counties"
> STYLE
> COLOR 255 255 153
> OUTLINECOLOR 204 153 51
> END
> END
> END
> LAYER
> NAME "Test Points"
> STATUS DEFAULT
> TYPE POINT
> CONNECTIONTYPE POSTGIS
> CONNECTION "user=username dbname=nat_db host=localhost
> password=password"
> DATA "the_geom from test_points"
> CLASS
> NAME "Points"
> STYLE
> SYMBOL 7
> COLOR 255 0 0
> SIZE 5
> END
> END
> END
> END
> Any help / suggestions appreciated.
> -Ken-ichi
