problems using a cascaded layer - wms_name parameter
Nuno GIL
nunoragil at GMAIL.COM
Tue Mar 22 07:29:52 EST 2005
Thank you once more Bart!
Well, the actual name of the layer on the remote WMS is
"/landmap/mosaics/landsat/l5mosaic.ecw".
After reading the bug report, I have the impression that this nesting
capability is only valid and accessed inside the "wms_layer_group"
keyword. Am I wrong?
Regards,
Nuno
On Mon, 21 Mar 2005 17:06:11 +0100 (CET), bartvde at xs4all.nl
<bartvde at xs4all.nl> wrote:
> Hi Nuno,
> if you use a WMS layer in Mapserver WMS client, you just use the name (as
> present in the WMS capabilities between <Name>...</Name>), not the
> nesting, in your case probably:
> "wms_name" "l5mosaic.ecw"
> Or are you sayig the actual name of the layer on the remote WMS is
> "/landmap/mosaics/landsat/l5mosaic.ecw"?
> The / syntax is for Mapserver as a WMS server (wms_layer_group),
> indicating how it should build up its WMS capabilities with nesting.
> See:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=776
> Hope this helps.
> Best regards,
> Bart
> > Dear listers,
> > I am trying to use a cascaded layer.
> > I call it on my map file like this
> > "wms_name" "/landmap/mosaics/landsat/l5mosaic.ecw"
> > The server produces an error saying that it is unnable of displaying
> > that same layer.
> > Does anyone know how to deal with this issue? I do believe that the
> > problem is the slash usage...
> > Regards,
> > Nuno
