shapefile class declaration
Frank Warmerdam
fwarmerdam at GMAIL.COM
Tue Mar 22 14:01:58 EST 2005
On Tue, 22 Mar 2005 13:53:04 -0500, Jeff Portwine <jdport at veritime.com> wrote:
> Can anybody tell me what the different "types" of shapefiles would
> represent? The documentation lists them but doesn't describe them.
> I'd guess that the MS_SHP_POLYGON would be a set of points that defines a
> closed shape while the MS_SHP_MULTIPOINT would be points defining lines
> (such as roads or rivers or whatever)....
> Would MS_SHP_ARC then be an ESRI type shapefile? And what would
> MS_SHP_POINT be? That sounds like a single point but why would you create a
> shapefile for a single point?
Jeff,
MS_SHP_POINT means each feature has a single associated point,
not that there is only a single point in the whole file.
MS_SHP_MULTIPOINT is when you have a set of points associated
with a feature, but not generally any lines drawn between them. This
is rarely used.
MS_SHP_ARC is a normal polyline file for roads and such.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
