Red Hat & PHP/MapScripts
blaise bpicinbono at WORLDONLINE.FR
Wed Mar 23 08:23:15 EST 2005
Le mercredi 23 Mars 2005 09:57, Andrew Swiader a écrit :
> Hello list,
> I have a problem with PHP/MapScripts compilation on Red Hat 9. When I
> configure MapScripts from the source file, an error message appears (see
> below). The error message tells me that the DG and freetype, libpng,
> libjpeg or libiconv are not added, but I have done this. If I am trying on
> the newer GD libraries (2.0.21), there is same error.
> Thanks for help in advance.
> Andrew
Hi Andrew.
How did you install GD, freetype, etc... rpm ? If yes,  then I think you need
the -devel rpm of each one.
Have you read this wiki doc about MapScript install on redhat 9 :
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?RedHat9AndMapserver40
It should work nicely.
Hope it'll help.
Blaise
