mapscript installation on debian
James Cradock
jcradock at ME3.COM
Thu Mar 24 08:49:00 EST 2005
Oops. Ed McNierney pointed out for me on 3/15 that I want MapServer
configured without tiff support -- GDAL will provide that -- and my
instructions here don't reflect this change:
"--with-tiff" should be changed to "--without-tiff"
Thanks, Ed.
On Mar 24, 2005, at 8:43 AM, James Cradock wrote:
> This all assumes that Apache2 and PostgreSQL with PostgreSQL's
> libraries are installed. Also assumed: That you're running Debian Sarge
> ("testing"). (Watch the line breaks!)
> Change to user root and bring APT up-to-date:
> apt-get update
> 1. Supporting libraries:
> Install libraries to make MapServer useful -- many of these are
> documented on the UNIX installation page on MapServer's online
> documentation:
> apt-get install libgd2 libgd2-dev proj libcurl3 libcurl3-dev libtiff4
> libtiff4-dev libjpeg62 libjpeg62-dev freetype2 libgdal1 libgdal1-dev
> 2. PHP:
> PHP must be run as a CGI and it must be configured and built with
> system regular expressions. This install of PHP will give you PHP as a
> CGI with system regex wihout clobbering mod_php (if it's installed)
> with its built-in regex -- note that I'm installing the PHP I want to
> use with MapServer in /usr/local/php_for_mapserver-4.3.10 and that I'm
> symlinking it to make upgrading PHP easier:
> cd /usr/local/src
> apt-get source php4-cgi
> cd php4-4.3.10
> ./configure --prefix=/usr/local/php_for_mapserver-4.3.10 --enable-dbase
> --with-jpeg=/usr --with-tiff=/usr --with-gd=/usr --with-png=/usr
> --with-freetype --with-zlib --with-regex=system
> make
> make install
> cp php.ini-dist /usr/local/php_for_mapserver-4.3.10/lib/php.ini
> cd /usr/local
> ln -s php_for_mapserver-4.3.10 php_for_mapserver
> Setup Apache to execute all *.phtml as PHP CGI. First edit
> /etc/apache2/sites-enabled/default (or whatever your default
> configuration is):
> <Directory "/var/www/mapserver">
> AddType application/x-httpd-php-cgi .phtml
> Action application/x-httpd-php-cgi /cgi-bin/php
> </Directory>
> Then add this shell script, called "php", to the /usr/lib/cgi-bin
> directory:
> #!/bin/sh
> export SCRIPT_FILENAME=$PATH_TRANSLATED
> /usr/local/php_for_mapserver/bin/php -c
> /usr/local/php_for_mapserver/etc/php.ini
> Make it executable:
> chmod 755 /usr/lib/cgi-bin/php
> Make the "mapserver" directory:
> mkdir /var/www/mapserver
> And make a phpinfo.phtml file:
> echo "<?= phpinfo() ?>" > /var/www/mapserver/phpinfo.phtml
> If you restart Apache ("apache2ctl restart") and navigate to
> "http://127.0.0.1/mapserver/phpinfo.phtml" you'll see the output you'd
> otherwise see loading a page with phpinfo() with the *.php extension.
> 3. MapServer:
> cd /usr/local/src
> wget http://cvs.gis.umn.edu/dist/mapserver-4.4.1.tar.gz
> tar -zxvf mapserver-4.4.1.tar.gz
> cd mapserver-4.4.1
> ./configure --prefix=/usr/local/mapserver-4.4.1 --with-jpeg
> --with-freetype=/usr/local --with-zlib --with-png --with-tiff
> --with-gd=/usr --with-proj=/usr --with-gdal=/usr/bin/gdal-config
> --with-wmsclient --with-php=/usr/local/php_for_mapserver
> --with-postgis=/usr/bin/pg_config --with-mygis=/usr/bin/mysql_config
> make
> make install
> "make install" will print this message to your terminal window:
> ***** MapServer Installation *****
> To install MapServer, copy the 'mapserv' file to your web server's
> cgi-bin
> directory.
> If you use MapScript then see the documentation for your specific
> MapScript
> version for installation instructions.
> Copy "mapserv" to the CGI-BIB directory:
> cp mapserv /usr/lib/cgi-bin/mapserv
> Enable PHP/MapScript:
> cd mapscript/php3
> mkdir /usr/local/php_for_mapserver/lib/php/20020429
> cp php_mapscript.so /usr/local/php_for_mapserver/lib/php/20020429/
> In /usr/local/php_for_mapserver/lib/php.ini set the extension_dir to
> /usr/local/php_for_mapserver/lib/php/20020429/, enable the
> PHP/MapScript module:
> extension=php_mapscript.so
> And copy php_mapscript.so to the extensions directory:
> Now you don't need to load the module in your PHP script.
> Restart Apache and go again to
> "http://127.0.0.1/mapserver/phpinfo.phtml". You'll see a block for
> MapScript.
> 4. Gotchas:
> * I've enabled MapServer and PHP/MapScript with support for MyGIS. You
> may need to install MySQL 4.1's client libraries:
> apt-get install libmysqlclient14 libmysqlclient14-dev
> * mod_action may need to be enabled in Apache. It's disabled in Debian
> by default:
> cd /etc/apache2/mods-enabled
> ln -s /etc/apache2/mods-available/actions.load .
> * Again, this all assumes that Apache2 and PostgreSQL with PostgreSQL's
> I hope this helps. Let me know if I should make changes to these
> instructions.
> Thanks.
> Jim
> On Mar 23, 2005, at 10:23 AM, Lehuta Juraj - OZ wrote:
>> Yes, it will be fayn,
>> thank you very much
>> WochteR
>> -----Original Message-----
>> From: James Cradock [mailto:jcradock at me3.com]
>> Sent: Wednesday, March 23, 2005 4:15 PM
>> To: Lehuta Juraj - OZ
>> Subject: Re: [UMN_MAPSERVER-USERS] mapscript installation on debian
>> I would install all the supporting software (apache2, proj, gdal, gd,
>> etc --
>> look at the MapServer UNIX installation docs) from APT and build PHP
>> (to run
>> as a CGI alongside mod_php) and MapServer from source. I've got an
>> utterly
>> straightforward installation recipe, including input for a gotcha or
>> two
>> I've gotten help with from this list, for Sarge, and I can send it to
>> you
>> later today and amend it to the Debian topic on the MapServer Wiki.
>> Jim
>> On Mar 23, 2005, at 10:04 AM, Lehuta Juraj - OZ wrote:
>>> yes,
>>> extension_dir /usr/lib/php4/20020429-zts /usr/lib/php4/20020429-zts
>>> and mapscript.so is realy in this directory
>>> my Debian is:
>>> sarge
>>> Linux mapserver 2.6.8-1-686 #1 Thu Nov 25 04:34:30 UTC 2004 i686
>>> GNU/Linux
>>> I installed mapserver and mapscript packages from deb
>>> http://agrogeomatic.educagri.fr/debian woody main
>>> by:
>>> apt-get install php-mapscript cgi-mapserver php4
>>> When I remove the mapscript.so from /usr/lib/php4/20020429-zts I
>>> obtain this:
>>> Warning: dl(): Unable to load dynamic library
>>> '/usr/lib/php4/20020429-zts/php_mapscript.so' -
>>> /usr/lib/php4/20020429-zts/php_mapscript.so: cannot open shared
>>> object
>>> file:
>>> No such file or directory in /var/www/test.php on line 2
>>> ** cannot open shared object file***
>> James Cradock, jcradock at me3.com
>> me3 Technology Consultants, LLC
>> 24 Preble Street, 2nd Floor
>> Portland, ME 04101
>> 207-772-3217 (office)
>> 207-838-8678 (mobile)
>> www.me3.com
> Portland, ME 04101
> www.me3.com
Portland, ME 04101
www.me3.com
