PHP/Mapscript Crash...
Don Drake dondrake at GMAIL.COM
Fri Mar 25 18:42:54 EST 2005
I'm having the exact same problem on Solaris.  We're porting our app
(PHP & PostGIS) to Solaris for a trial and have run into this problem.
  Everything else is working just fine.
If I change the maps LABEL to BITMAP, then I see the text, otherwise,
when it draws() it gives doesn't give an error, just dies.  I've
trussed the httpd process and don't see anything that's failing.
I have gd 2.33 and freetype 2.1.9.
MapServer Version 	MapServer version 4.2.5 OUTPUT=GIF OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
PHP MapScript Version 	($Revision: 1.194.2.6 $ $Date: 2004/08/25 16:27:43 $)
Thanks.
-Don
On Fri, 25 Feb 2005 09:38:55 -0700, Corey Puffalt <cplists at gmail.com> wrote:
> I'm using the stock Fedora Core 2 php rpms (upgraded to the latest
> updates).  According to phpinfo it was compiled with --with-gd ... the
> php.ini is located in /etc/php.ini it also references any files in
> /etc/php.d.  Neither php.ini nor the php.d refers to gd.so or libgd.so
> anywhere as far as I can see...
> Corey
> On Fri, 25 Feb 2005 17:24:28 +0100, Benoît Toutain <bf.toutain at free.fr> wrote:
> > No I use a debian.
> > Did you compile you PHP with GD library ( option --with-gd when you
> > execute ./configure) (see it in the first array of phpinfo() ) ?
> > Do you edit the right php.ini file (the right file is given in the first
> > array when you display php information)
> > If you really don't find the gd shared object (gd.so or libgd.so or ....
> > ) in your php.ini file and on you FC2, you must recompile PHP without
> > the GD library
> > Corey Puffalt a écrit :
> > >Yes there's a GD section when viewing phpinfo();  Are you running FC2?
> > >Thanks,
> > >Corey
> > >On Fri, 25 Feb 2005 16:57:41 +0100, Benoît Toutain <bf.toutain at free.fr> wrote:
> > >>Hi Corey,
> > >>perhaps the name of your library file is libgd.so or something like
> > >>that.... or your problem does not come from conflicts between two GD
> > >>libraries. Have you got a GD section when you make a <?php phpinfo(); ?>  ?
> > >>Benoît
> > >>>My php.ini doesn't appear to have an extension=gd.so line... nor do
> > >>>any of the files in php.d/* do anyone know how to disable the gd
> > >>>extension with the stock FC2 rpms?
> > >>>Thanks,
> > >>>Corey
> > >>>On Fri, 25 Feb 2005 09:22:59 +0100, Benoît Toutain <bf.toutain at free.fr> wrote:
> > >>>>I commented the extension=gd.so line in my php.ini and restarted apache
> > >>>>and now it works.
> > >>>>No more crash for me too :-)
> > >>>>Thanks a lot
> > >>>>Best regards
> > >>>>Benoît
> > >>>>Constantin Cristian a écrit :
> > >>>>>I got the same problem, I googled for some answers:
> > >>>>>>Use phpinfo() to see if PHP has GD enabled, if it does then either
> > >>>>>>disable the PHP GD extension or make sure that both PHP and MapScript
> > >>>>>>use the same GD version.  Also make sure that there is only one copy
> > >>>>>>of libgd.so and of the GD headers on your system.
> > >>>>>So I rebuilt my php installation and this time I used the gd that used to
> > >>>>>build mapscript rather then the bundled php gd
> > >>>>>and surprise... it doesn't crash anymore.
> > >>>>>----- Original Message -----
> > >>>>>From: "c p" <cplists at GMAIL.COM>
> > >>>>>To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> > >>>>>Sent: Thursday, February 24, 2005 7:47 PM
> > >>>>>Subject: Re: [UMN_MAPSERVER-USERS] PHP/Mapscript Crash...
> > >>>>>Benoit,
> > >>>>>Well at least there's someone else to share my pain. :P  After doing
> > >>>>>some more reading today I realized I wasn't running php as a cgi but
> > >>>>>as an apache DSO so I thought that must be my problem.  Is it still
> > >>>>>true that PHP/Mapscript v4.4.1 still must be run as a cgi?  Anyway, I
> > >>>>>reconfigured Apache to call php as a cgi but that did not resolve the
> > >>>>>crash. :(
> > >>>>>Regards,
> > >>>>>Corey
> > >>>>>On Thu, 24 Feb 2005 13:54:54 +0100, Benoît Toutain <bf.toutain at free.fr>
> > >>>>>wrote:
> > >>>>>>Hi Corey,
> > >>>>>>I have the same pb as you.
> > >>>>>>Here is my configuration obtained with <?php
> > >>>>>>dl('php_mapscript.so');phpinfo(); ?>
> > >>>>>>MapServer version 4.2.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF
> > >>>>>>SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> > >>>>>>SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS
> > >>>>>>INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > >>>>>>Is not there compatibity problems with freetype libraray and another
> > >>>>>>one ?
> > >>>>>>Hope everybody can show us the right way ;-)
> > >>>>>>Best regards,
> > >>>>>>Benoît
> > >>>>>>c p a écrit :
> > >>>>>>>All,
> > >>>>>>>I'm hoping someone here can help or can point me to a more appropriate
> > >>>>>>>forum.  I've been having problems getting the samples that ship with
> > >>>>>>>Chameleon v2.0 fully functional.  When I attempt to view one of the
> > >>>>>>>sample maps I'm getting a segmentation fault:
> > >>>>>>>==> error_log <==
> > >>>>>>>[Wed Feb 23 15:59:59 2005] [notice] child pid 18222 exit signal
> > >>>>>>>Segmentation fault (11)
> > >>>>>>>By enabling/disabling different layers I was able to narrow the
> > >>>>>>>problem down to the popplace layer and specifically the FONT, TYPE &
> > >>>>>>>SIZE tags (which specify a truetype font) inside the LABEL definition.
> > >>>>>>>Commenting out these three tags result in the layer displaying
> > >>>>>>>(albeit with the default bitmap font).  Although I've narrowed what
> > >>>>>>>triggers the crash I still have no idea how to rectify the problem.
> > >>>>>>>I'm further puzzled by the fact that when I use shp2img to render the
> > >>>>>>>map it works fine which seems to suggest the problem is specific to
> > >>>>>>>the php/mapscript module?
> > >>>>>>>I'm running Fedora Core 2 & Mapserver v4.4.1 using the RPMs hosted at
> > >>>>>>>the Mapping Hacks website (http://mappinghacks.com/rpm/).  I've
> > >>>>>>>attached the chameleon.map file in case that helps.
> > >>>>>>>Any help would be appreciated.
> > >>>>>>>Thanks,
> > >>>>>>>Corey
Donald Drake
President
Drake Consulting
http://www.drakeconsult.com/
http://www.MailLaunder.com/
http://www.mobilemeridian.com/
312-560-1574
