Query Mode
Mike Davis
mike.and.kerry at GMAIL.COM
Tue Mar 29 14:35:41 EST 2005
You might try a simple redirect to send the information to a database
query page. For example, one of my applications links to a project
status database. When a user uses the identify tool my template
contains a some javascript like this:
window.location="http://link/to/database/page.php?project_id=[ID_FIELD]";
In this case the [ID_FIELD] is replaced with the value from the .dbf
table and the page is redirected.
Hope this helps.
-Mike
On Sat, 26 Mar 2005 03:13:02 -0500, Giridhar Manepalli
<gmanepal at gmail.com> wrote:
> Hello All,
> When I set the mapserver(CGI) in query mode(based on query templates)
> and click on a layer, I am ABLE to get the information from the dbf
> file.
> Now,
> 1.) How can I send the lat/long of the click that I make to a PostGIS
> table and retrieve information based on the lat/long?
> 2.) Also, is it possible to get the information from the dbf and query
> the PostGIS table based on information from the dbf. For example,
> .dbf file has ID=1 for a feature. Now, when I click on a feature, can
> I get the ID value and subsequently query the PostGIS table for UUID
> based on ID before I display both the UUID and ID?
> click -> get ID from dbf
> -> get UUID from PostGIS table using ID
> -> Display UUID and ID
> I appreciate if someone can suggest me a way to tackle these two issues.
> Thanks,
> Giridhar
