WFS bug? - multiple layers from same service
Godwin, Elizabeth
Godwinl at AGR.GC.CA
Tue Mar 29 15:24:25 EST 2005
I'm experiencing a wierd phenomenon with a mapfile i am working with.
It's a bit of a unique case in that the map is composed of 3 layers, all
WFS layers coming from the same service.
The odd thing is...when I do this... only the FIRST layer in the map is
drawn, but using the class info from the LAST layer of this service. If
I draw the middle layer from a different service...the same is true,
except that middle layer draws normal. So FIRST is drawing with THIRD
styling, on top of SECOND that has it's own styling.
In this case, it's polygons, lines and points, so the polygons are
drawing with point symbology on top of lines. Or if all are coming from
the same service, all that is drawn is polygins with point symbology.
The last two layers are not drawn.
I'm working with a cvs version from a month ago or so, but I also tested
against 4.4.0
Shall I post a bug? I'm asking first in case I've overlooked something
silly.
Liz Godwin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050329/1ac6d96a/attachment.html
