Projection Issues
Bill Binko
bill at BINKO.NET
Tue Mar 29 16:46:27 EST 2005
ACK!
Ok, I don't know whether to kiss or kick you.
It fixed the problem of course.
Ugh
Well, when I'm finished being mortified, I have some other questions :)
Thanks Ed (and Paul)!
Bill
<..slinks back under his rock>
On Tue, 29 Mar 2005, Ed McNierney wrote:
> Bill -
> You have no CLASS definition to describe the rendering style to be used
> for your "Pinellas Roads" layer. Add one, similar to the way you did
> for the county outline layer - obviously, there's no OUTLINECOLOR
> needed, and make sure you choose a color that's different than the
> county polygon fill color!
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: Bill Binko [mailto:bill at binko.net]
> Sent: Tuesday, March 29, 2005 2:49 PM
> To: Ed McNierney
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: RE: [UMN_MAPSERVER-USERS] Projection Issues
> On Fri, 25 Mar 2005, Ed McNierney wrote:
> > Bill -
> > Those all look reasonable - good job! Those SRID codes are EPSG
> > projection codes, and you can use them directly as:
> > PROJECTION
> > "init=epsg:26759"
> > END
> > which will save you a lot of typing and some typos! It also makes it
> > obvious to the reader what projection it is (or at least easy for the
> > reader to look up).
> > Could you post your entire MAP file? Since your output is in the
> > state plane projection, your EXTENT needs to be specified in that
> > projection and units. I would recommend that you start with a map
> > file with the county PROJECTION block at the MAP level and one layer
> > with the county data, also with the same PROJECTION block. Get that
> > working correctly, the add the second layer with the UTM PROJECTION
> block.
> Ed,
> I took your advice and and replaced the projections with the espg codes.
> I also simplified the map file to just have two layers: both shapefile,
> not PostGIS. However, I am still having the same problem: I only see
> the county data when I put both in the file.
> I've included the reduced map file below, and I've sent a copy of the
> data to Paul to see if he can help. Is there a standard way to
> distribute layer files for review on this board? Or should I post a URL
> or the like?
> Thanks for your time,
> Bill
> MAP
> NAME SINKHOLE
> STATUS ON
> SIZE 800 500
> IMAGETYPE PNG
> IMAGECOLOR 240 240 255
> SHAPEPATH "/var/www/binko.net/maps/data/"
> UNITS METERS
> EXTENT 57968.750000 1189453.125000 464218.750000 1443359.375000
> PROJECTION
> "init=epsg:26759"
> END
> WEB
> TEMPLATE "/var/www/binko.net/maps/template1.html"
> IMAGEPATH "/var/www/binko.net/maps/tmp/"
> IMAGEURL "/maps/tmp/"
> LOG "/var/www/binko.net/maps/error.log"
> END
> SCALEBAR
> STATUS ON
> STYLE 1
> INTERVALS 4
> SIZE 200 2
> COLOR 0 0 0
> OUTLINECOLOR 0 0 0
> UNITS miles
> LABEL
> COLOR 0 0 0
> SIZE small
> END
> END
> LAYER
> NAME "Pinellas County Outline"
> PROJECTION
> "init=epsg:26759"
> END
> TYPE LINE
> STATUS DEFAULT
> DATA "co_outline0000100104_line"
> CLASS
> NAME "Pinellas County"
> OUTLINECOLOR 60 60 60
> COLOR 200 200 200
> SYMBOL 0
> END
> END
> LAYER
> NAME "Pinellas Roads"
> TYPE LINE
> STATUS DEFAULT
> PROJECTION
> "init=epsg:26917"
> END
> DATA "localnam"
> DEBUG ON
> END
> END
