Projection Help GPS vs National Atlas
Ed McNierney ed at TOPOZONE.COM
Wed Mar 30 08:58:50 EST 2005
James -
Could you explain what you mean by "stored first in the shapefile"?
Shapefile coordinates are unitless X and Y numbers - longitude is an X
coordinate, and latitude is a Y coordinate (at least if you pretend the
Earth is flat).
You're free to use "proj=longlat" if you find that easier.
        - Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of James Goddard
Sent: Wednesday, March 30, 2005 8:19 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Projection Help GPS vs National Atlas
James Goddard wrote:
>I'm a little confused by all of the projection stuff.  Any help would
>be appreciated.
Ok, I figured this one out.  It wasn't a projection problem, it turns
out that even though the projection is latlong the long needs to be
stored first in the shapefile.  Go figure.
Thanks for the help.
James
