WFS bug? - multiple layers from same service
Godwin, Elizabeth Godwinl at AGR.GC.CA
Thu Mar 31 12:37:28 EST 2005
POST is definitely working, as two separate requests on the server, one
for each service (looked into access log for apache).
Line from debug is:
Thu Mar 31 11:32:12 2005,24623,10.117.202.73,ShapeIndexWFS,3,-142.621725
41.189137 -47.378275 88.810863,-95.000000 65.000000,one two three
,normal execution
> -----Original Message-----
> From: Bart van den Eijnden [mailto:bartvde at xs4all.nl]
> Sent: March 30, 2005 1:05 PM
> To: Godwin, Elizabeth; MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] WFS bug? - multiple layers
> from same service
> Hi Liz,
> Just thinking out loud, that does sound like cache to me :)
> Do you have DEBUG ON on your layer and MS_ERRORFILE set? That could
> provide more info for this issue, there is a statement in there when
> something is read from cache if I remember correctly.
> Can you specify explicitly wfs_request_method "POST" on all
> the layers to
> test?
> Best regards,
> Bart
> On Wed, 30 Mar 2005 13:03:55 -0500, Godwin, Elizabeth
> <Godwinl at AGR.GC.CA>
> wrote:
> > Hi Bart,
> > There was only 1 gml file when I call the map with all three layers
> > coming from the same source.  Inside the gml, there is only gml for
> > the one layer.
> > When I do it again with the middle layer coming from a different
> > source, there are two gml.  I didn't look, but I suspect
> one for the
> > first layer, one for the second.
> > Cheers,
> > Liz
> >> Sent: March 30, 2005 12:45 PM
> >> Subject: Re: [UMN_MAPSERVER-USERS] WFS bug? - multiple layers from
> >> same service
> >> Hi Liz,
> >> could this have something to do with the WFS client caching
> >> mechanism? But if I look at your MAP file you don't specify the
> >> wfs_request_method GET
> >> metadata so if your Mapserver is new enough it should default
> >> to POST, and
> >> POST uses no cache at the moment.
> >> How many GML files do you see coming into your IMAGEPATH
> directory in
> >> the first case you describe where all layers come from the same
> >> WFS service?
> >> Best regards,
> >> Bart
> >> On Tue, 29 Mar 2005 15:24:25 -0500, Godwin, Elizabeth
> >> wrote:
> >> > I'm experiencing a wierd phenomenon with a mapfile i am
> >> working with.
> >> > It's a bit of a unique case in that the map is composed of
> >> 3 layers,
> >> > all WFS layers coming from the same service. The odd thing
> >> is...when I
> >> > do this...  only the FIRST layer in the map is drawn,
> but using the
> >> > class info from the LAST layer of this service.  If I draw
> >> the middle
> >> > layer from a different service...the same is true, except
> >> that middle
> >> > layer draws normal.  So FIRST is drawing with THIRD
> >> styling, on top of
> >> > SECOND that has it's own styling. In this case, it's
> >> polygons, lines
> >> > and points, so the polygons are drawing with point
> >> symbology on top of
> >> > lines.  Or if all are coming from the same service, all
> >> that is drawn
> >> > is polygins with point symbology. The last two layers are not
> >> > drawn. I'm working with a cvs version from a month ago or so, but
> >> I also tested
> >> > against 4.4.0
> >> > Shall I post a bug?  I'm asking first in case I've
> >> overlooked something
> >> > silly.
> >> > Liz Godwin
> >> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
