mapserv segfaults trying to get thequery results of a native oracle spati
Nicol Hermann mapserver at GEOWORLD.DE
Mon May 2 10:59:49 EDT 2005
Hi Fernando,
is it mandatory to use numeric field types as UNIQUE column in the data
statement? At the moment i use a character field. I assume this is the
reason for the wrong shapeindex value, right?
Thanks
Nicol
Am Montag, den 02.05.2005, 11:35 -0300 schrieb Fernando Simon:
> Hi Nicol,
>     You can change the data parameter for any sql that return a geometry
> type.  In your case you can add "WHERE" inside the data stmt, like:
> DATA "GEOMETRIE from (SELECT ID, INFOTEXT, BESCHRIFT, GEOMETRIE FROM
> FLURST WHERE ID > 0) USING UNIQUE ID SRID 82027"
>     Here I don't use the "select *", but you can use without problem.
>     About the example, you can define your sql with where's, join's,
> functions and spatial functions between the "(" and ")". The
> maporaclespatial.c don't change this sql, it's mount the internal sql
> using your sql as base.
>     Just as hint, the column that you define as UNIQUE, ID in your case,
> must be a numeric type. Only numbers, and it's need to be unique
> identifiers for your table. More one hint, you can start your counter
> "j" with 1 and test the if occur the same problem.
>     Thanks.
> Fernando Simon
> Mapserver and Oracle Spatial developer
> G10 - Laboratorio de Computacao Aplicada - Brazil
> http://g10.cttmar.univali.br - UNIVALI/CTTMAR
> Nicol Hermann wrote:
> >Hi Fernando,
> >thank you for your answer!
> >I found a problem in my code.
> >I opened the layer before i send the query. I changed this to:
> >$status = $Layer -> queryByPoint($geometrie, MS_MULTIPLE, 100);
> >$Layer->open();
> >for($j = 0;$j < $Layer->getNumResults(); $j++) {
> >   $oRes = $Layer->getResult($j);
> >   $shpobj = $Layer->getShape($oRes->tileindex,$oRes->shapeindex);
> >   $shpobj->free();
> >$Layer->close();
> >Now i get a mapserver error message:
> >Fatal error: [MapServer Error]: msOracleSpatialLayerGetShape(): Error:
> >ORA-01722: Ungultige Zahl . Query statement: SELECT ID, INFOTEXT,
> >BESCHRIFT, GEOMETRIE FROM (SELECT * FROM FLURST) WHERE ID = 0 .Check
> >your data statement.
> >Here is my data statement:
> >DATA "GEOMETRIE from (SELECT * FROM FLURST) USING UNIQUE ID SRID 82027"
> >The value of the variable '$oRes' are:
> >stdClass Object
> >    [shapeindex] => 0
> >    [tileindex] => -1
> >    [classindex] => 0
> >How do i have to change the data statement to get a valid shapeindex?
> >I'am not sure that the solution found for bug #1244 solves my problem
> >with the "--enable-point-z" flag. I use the latest cvs version which
> >should contain the fix, right?
> >Many thanks for your help
> >Nicol
