escaping single quotes
Ryan, Adam
ARyan at CO.LINN.OR.US
Tue May 3 12:45:30 EDT 2005
> -----Original Message-----
> From: Paul Scott [mailto:pscott at UWC.AC.ZA]
> Sent: Monday, May 02, 2005 4:50 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] escaping single quotes
> Two other things you could try:
> use htmlspecialchars();
> or str_replace the "'" with '
> That will make it look like ' . $gemnaam;
> which will echo to 'genmaan
> --Paul
> >>> Ace Suares <ace at SUARES.NL> 05/02/05 1:30 PM >>>
> On Monday 02 May 2005 5:08, Paul Scott wrote:
> > One word:
> > addslashes();
> > PHP does it for you with the function addslashes(); '[GEMNAAM]'=
> > addslashes('$gemnaam');
> Tried that, didn't work. A \' is not recognized by mapserver.
> Correct me if I am wrong.
> I got the tip from some else (off-list) to us two single
> quotes in a row, like '[GEMNAAM]'=''s-Gravenhage' Haven't
> tested it yet.
> I would prefer that mapserver/mapscript would honour addslashes().
> _Ace
> > --Paul
> > >>> Ace Suares <ace at SUARES.NL> 05/02/05 4:53 AM >>>
> > dear list,
> > I have the following situation:
> > 1. a column in my shapefile (.dbf) that is called GEMNAAM
> > 2. 482 gemeentes (counties), 3 of them starting with an ' (an
> apostroph
> > or
> > single quote).
> > 3. a filter that looks like '[GEMNAAM]'='$gemnaam'
> > where $gemnaam iterates over (some of) the 482 gemeentes
> > The problem seems to be that the single quote in the
> $gemnaam is not
> > being escaped, and I have no idea how to escape it.
> > Is there an escape mechanism for single quotes ?
> > I tried double quotes i.e. '[GEMNAAM]'="$gemnaam" but
> apparently to no
> > avail.
> > Much obliged for any hint. (However, that won't bring back
> the past 4
> > hours of my life).
> > _ace
> It's not possible to treat coherently that which is incoherent.
> - Date's Incoherence Principle
> Ace Suares' Internet Consultancy
> mail: PObox 2599, 4800 CN Breda, The Netherlands
> phone: +31 6 244 33 608 (Jan Veuger, support Netherlands)
> emergency: +599 786 23 73
> voicemail & fax: +31 848 707 705
> web: http://www.suares.nl email: support at suares.nl
Ace,
Have you solved this problem? We might have similar but different problems
because I'm using Python mapscript but I found that a field that has any
apostrophe in any record in rendered unsearchable no matter what I do.
Adam
