working with filters and expressions
James Anderson
james at DANISAT.NET
Wed May 4 02:54:03 EDT 2005
Hi all,
I have a great problem.
I have a shape file layer of some roads. All the different road types are in the same shape file, and Attibute data is used to specify the road type. I have a attribute/column named TYPE. The data here ... eg road types are Paved,Unpaved, Dirt Road, etc
Now what I want is to filter out the road types I dont want. For this I was assuming the FILTER paramenter under the layer could work.
I have now tried numerous things but nothing much works. I see lots of others having problems with this. Reading posts here I see lots of conflicting info. Some also say you can do the same with the EXPRESSION parameter under your class.
Now I am totally confused. I have tired things like
FILTER "([TYPE]='Paved' or [TYPE]='Unpaved')"
FILTER "([TYPE] eq 'Paved' or [TYPE] eq 'Unpaved')"
To try and show only paved and unpaved roads.
I get nothing .. not a single thing shows up. Yet if I remove the filter parameter, all the roads types show.
So I also tried
FILTER "([TYPE]='Paved')"
FILTER "([TYPE] eq 'Paved')"
FILTER ([TYPE]='Paved')
FILTER ([TYPE] eq 'Paved')
I get same result .. nothing shows when the filter is present.
However, I have managed to get one thing working:
FILTERITEM "TYPE"
FILTER "Paved"
This works in that it shows only paved roads. Yet the moment I try and get it to work on more than one roadtype, it freaks out and shows nothing. I tried doing similar things with the Expression parameter but also with no results.
My Layer looks like this:
LAYER
NAME "tr_ro_final"
TYPE line
CONNECTIONTYPE OGR
CONNECTION "/maps/tr_ro_final.shp"
STATUS DEFAULT
#FILTER "[TYPE] eq 'Unpaved'"
#FILTERITEM "TYPE"
#FILTER '!"Dirt Road"'
#MINSCALE 3.01
#MAXSCALE 99.01
CLASS
#Expression ([TYPE] eq "Unpaved")
#COLOR 151 75 0
COLOR 255 0 0
SYMBOL "circle"
SIZE 3
END
END
As you can see I have still left in some of the things I was playing with. Still .. I have not got far. I have not been able to find any proper documentation of using mapserver regex or using the filter parameter properly.
My mapserver version:
MapServer version 4.4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Can anyone help me ? I am desperate to finally figure this out once and for all.
Thanks,
James Anderson.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050504/dcaeb21b/attachment.html
