working with filters and expressions
Sean Gillies
sgillies at FRII.COM
Wed May 4 09:11:12 EDT 2005
On May 4, 2005, at 12:54 AM, James Anderson wrote:
> This is a multi-part message in MIME format.
> ------=_NextPart_000_00C0_01C55086.D2691930
> Content-Type: text/plain;
> charset="Windows-1252"
> Content-Transfer-Encoding: quoted-printable
> Hi all,
> I have a great problem. =20
> I have a shape file layer of some roads. All the different road types
> are in the same shape file, and Attibute data is used to specify the =
> road type. I have a attribute/column named TYPE. The data here ...
> eg =
> road types are Paved,Unpaved, Dirt Road, etc
> Now what I want is to filter out the road types I dont want. For this
> I =
> was assuming the FILTER paramenter under the layer could work.
> I have now tried numerous things but nothing much works. I see lots
> of =
> others having problems with this. Reading posts here I see lots of =
> conflicting info. Some also say you can do the same with the
> EXPRESSION =
> parameter under your class.
> Now I am totally confused. I have tired things like
> FILTER "([TYPE]=3D'Paved' or [TYPE]=3D'Unpaved')"
> FILTER "([TYPE] eq 'Paved' or [TYPE] eq 'Unpaved')"
James,
In MapServer's expression language, all variables on the left hand side
such as [TYPE] are evaluated numerically unless explicitly cast as
strings using quotes. The following should work
FILTER ("[TYPE]" = "Paved")
You would probably benefit from processing your data so that it has
integer type attributes to do
FILTER ([FTYPE] = 1) # Paved
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
