WMS GetMap not using Lat/Lonprojection
McGraw, Joanne
mcgrawj at AGR.GC.CA
Wed May 4 13:17:02 EDT 2005
Ah ha!
For this application, I am running MapServer 4.4.0-beta2 on the server.
I can find no mapserv-utils for that version just yet. I may need to
download it. I'll get back to you when I've run the shp2img with a
current version.
Cheers,
jtm
-----Original Message-----
Sent: Wednesday, May 04, 2005 1:05 PM
To: 'warmerdam at pobox.com'
Cc: MAPSERVER-USERS at lists.umn.edu
Subject: RE: [UMN_MAPSERVER-USERS] WMS GetMap not using
Lat/Lonprojection
DOH,
That's exactly what I am doing. The shp2img utility I was using was
3.6.3.
I find there are a number of versions MapServer on our server. How can I
find out which one is actually processing the pages I am requesting?
That is, while I was under the impression we are only one version behind
on the server, how can I find out for sure? The person who might know
this information is out of the office for a few days.
Anyone?
jtm
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
Sent: Wednesday, May 04, 2005 11:23 AM
To: McGraw, Joanne
Subject: Re: [UMN_MAPSERVER-USERS] WMS GetMap not using
Lat/Lonprojection
On 5/4/05, McGraw, Joanne <mcgrawj at agr.gc.ca> wrote:
> G'day, Frank,
> I tried your suggestion to use shp2img interactively to see if some
clue
> is provided. One was, but I don't know what to do with it.
> When I tried:
> This was the result:
> msLoadMap(): Unknown identifier. (config):(12)
> The config line in my map is:
> config PROJ_LIB /usr/local/proj-4.4.5/nad/
> As far as I can tell, that's the correct syntax for config. Uppercase
> CONFIG makes no difference...I tried.
Joanne,
Is there any chance you did this with an older shp2img? You
might want to check with "shp2img -v". The CONFIG keyword
was new in 4.4.0 as far as I know, but the message seems to
suggest the config keyword isn't recognised.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
