querymap symbology
Ryan, Adam
ARyan at CO.LINN.OR.US
Wed May 4 14:55:41 EDT 2005
Bart,
One method you might try is to define the layer you want to query twice. So
have a 'parcels' layer and a 'q_parcels' layer. The former would be
symbolized normally, the later would symbolized as you want the query
results to look. Then set the qlayer CGI variable to 'q_parcels', and in
your QUERYMAP object set STYLE to selected. But that's just one way.
Cheers,
Adam
> -----Original Message-----
> From: Bart van den Eijnden [mailto:bartvde at XS4ALL.NL]
> Sent: Wednesday, May 04, 2005 11:25 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] querymap symbology
> Hi list,
> I was wondering if the only property which can be set of
> selected features drawn in a querymap is the color?
> Is it not possible, to define line width, or eg whether or
> not labels should be drawn in the selection color as well?
> Have a selected polygon drawn filled instead of just the
> outline? I could even image a selection style per layer.
> Is it possible to do that kind of stuff? If yes then how?
> Thanks in advance.
> Best regards,
> Bart
> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
