Help: Perl/Mapscript Bug?
Sean Gillies
sgillies at FRII.COM
Thu May 5 13:42:38 EDT 2005
On May 5, 2005, at 11:21 AM, Stephen Woodbridge wrote:
> Hi all,
> I have run into an interesting but NASTY problem with Perl/Mapscript
> running in a fcgi process on Linux.
> Does anyone have any ideas?
> Is this a bug that has been fixed in a later release?
> Particulars:
> Debian Woody and Mapserver 4.01 - yes it is old, but it is a production
> system and we are concerned about the performance issues are in the
> later releases.
> The problem is that this script is running as an apache fcgi process
> and
> it is consuming all the system resources. An lsof shows that the
> shapefiles are not getting closed after each hit. We have tried to
> close
> the layer and undef the mapObj, but it does not fix the problem. It
> seems mapscript is not closing the file handles!!!
> We are going to try and test this under 4.4.1 and 4.4.2 and see what
> happens
> Any ideas?
> -Steve W.
Steve,
I don't even keep the 4.0 source around anymore, so I'm looking at 4.2.
I don't think maplayer.c had too many changes in between.
I suspect your problem is with the multiple calls to layerObj::open().
On the second call, a new shapefileObj will be allocated and the
layer's info pointer will be pointed to it, but it doesn't look like
the pre-existing one is ever freed. My comments continue below ...
> the Perl code is like:
> sub query {
> my $latitude = shift;
> my $longitude = shift;
> ## create new mapscript objec using appropriate mapfile
> my $map = new mapscript::mapObj($mapfile);
> return error("Can not open Mapfile: $mapfile") if not $map;
> ## get streets layer
> my $layer = $map->getLayerByName('data');
> return error("Can not open Layer: data") if not $layer;
> $layer->{status} = $mapscript::MS_ON;
> ## open the layer or the query will fail
> ## WHY DOES THIS NEED TO BE DONE HERE!
> $layer->open();
This is not necessary, and is probably the source of the leak. I've
never had problems querying a closed layer.
> ## build point obj using lat/lon
> my $point = new mapscript::pointObj();
> $point->{y} = $latitude;
> $point->{x} = $longitude;
> ## now query the layer object using lat/longs
> $layer->queryByPoint($map, $point, $mapscript::MS_SINGLE, -1.0);
> ## reopen layer to get results,
> ## you can't close it or it will lose the query info
> $layer->open();
> my $res = $layer->getResult(0);
Right. Open the layer only to get the results.
> ## get shape obj
> my $shp = new mapscript::shapeObj($layer->{type});
> $layer->getShape($shp, $res->{tileindex}, $res->{shapeindex});
> my $data;
> my $polyline = get_shp_xy($shp);
> ## do stuff with polyline put results into $data
> ## we tried $layer->close() and undef $map here
> ## but it did not make a difference
> return($data);
Hope that helps,
Sean Gillies
sgillies at frii dot com
http://zcologia.com
