debian apache packages
Didrik Pinte
dpinte at ITAE.BE
Fri May 6 08:11:21 EDT 2005
Le vendredi 06 mai 2005 à 14:55 +0300, orkun a écrit :
> hello
> I am confused with the debian apache packages
> to install mapserver in debian.
> which apache packages should be installed ?
> regards
> Ahmet Temiz
Depending on your needs, you need to choose Apache 1 or 2, if you need
Apache 2, install :
apache2-mpm-prefork apache2-mpm-prefork apache2-common
and it will run perfectly
Didrik
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050506/f6a138ac/attachment.bin
