saveWebImage() error in php application
Paul Spencer pspencer at DMSOLUTIONS.CA
Fri May 6 09:37:29 EDT 2005
Ahmet
the error messages indicate that you have a layer named 'fay' that is
using a shapefile kara_fay2 that it cannot find.
Make sure this shapefile exists in /usr/local/karabuk_data/kara_fay2 and
that this directory is readable by your apache user.
If yes to all of these, then perhaps your shapefile is corrupt in some
way.  Try opening it in some other way (ogrinfo perhaps?)
Paul
orkun wrote:
> *hello
> I couldn't overcome these problems:
> Warning*: [MapServer Error]: msDrawMap(): Failed to draw layer named
> 'fay'. in */var/www/cgi/mapd1.php* on line *402*
> *Warning*: [MapServer Error]: msSHPOpenFile():
> (/var/www/cgi/./kara_fay2) in */var/www/cgi/mapd1.php* on line *402*
> (/usr/local/karabuk_data/kara_fay2) in */var/www/cgi/mapd1.php* on line
> *402*
> *Fatal error*: Call to a member function saveWebImage() on a non-object
> in */var/www/cgi/mapd1.php* on line *403
> *what might lead these problems ?
> thanks in advance
> Ahmet Temiz
> ______________________________________
> XamimeLT - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the sender's
> own
> and do not necessarily represent the views and the opinions of
> Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
> olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
> nitelikte degildir.
|Paul Spencer                           pspencer at dmsolutions.ca   |
|Applications & Software Development                              |
|DM Solutions Group Inc                 http://www.dmsolutions.ca/|
