MyGIS and WFS
Bart van den Eijnden bartvde at XS4ALL.NL
Fri May 6 13:26:24 EDT 2005
Hi Stephanie,
I don't think a lot of Mapserver users are using MyGIS (or I must be
mistaken, which is possible ofcourse :) ). And probably not using the WFS
interface.
I never succeeded in compiling the Perl utility on Windows for loading the
shapefiles into MySQL. But probably compiling Mapserver against the MySQL
libraries won't be too hard.
If I would be in your shoes I would be moving to PostgreSQL/PostGIS.
Best regards,
Bart
On Fri, 06 May 2005 09:23:10 +0200, Stefanie Weykam <sweykam at TELELINE.ES>
wrote:
> Hi list members,
> Now that we have our prototype up and running, it's time to make some
> considerations for the future data incorporations.
> We are working with MapServer4.4 and MapScript on Windows2000. For now,
> we
> have all the spatial data (and all stable attributes) stored in
> shapefiles
> and all the survey data in MySQL.
> Query the data and render maps according to query results will be very
> important, as well as sharing data with others.
> I was wondering if we should migrate everything to MySQL as spatial
> database
> (tell me somebody that it is easy to compile MapServer with MyGIS
> support!?).
> How does this migration affect our WMS/WFS server capabilities? (makes it
> easier or more complicated?)
> Are the attribute data ONLY queriable if we have the spatial data in a
> spatial database?
> How would you render a polygon layer, having let's say 6 classes
> representing quantitative data on a colour ramp?
> I guess, one would first determine MIN and MAX values in a field, then
> the
> difference between MAX and MIN, divide this value by 6, create 6 class
> objects and 6 symbol objects, use 6 class expressions according to the
> previously determined value ranges and that's it (?). Can such a map be
> requested by a client?
> Another problem: The users would like to stick to Access as a database
> familiar to them. I know that it is possible to transfer locally stored
> Access tables to MySQL, then set up links in the Access database that
> point
> to the tables managed by the MySQL database server, but I have not tried
> it
> out. Is this an option or should we rather write an export/import
> routine?
> I'm afraid, actualisations will be quite frequent.
> Any comments would be appreciated,
> Stefanie Weykam
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
