queryByShape on PostGIS-Layer segfault in php-mapscript
Uwe Junge
ujunge at PMCENTRAL.COM
Fri May 6 15:08:27 EDT 2005
I have a similar Problem to the one posted on Sat, 18 May 2002 17:35:25
-0400 by <rburghol at vt.edu>
([mapserver-users] querybyshape on postgis layer segfault in php
mapscript ):
When executing queryByShape on PostGis-Layer i receive the following errors:
1) A windows-message
"The .. in 0x00d3bac5 points to memory in 0xffff. Unable to Read from
memory "
(original message was not in english)
2) followed by
"The CGI application misbehaved by not returning a complete set of
HTTP headers."
*** Map-File: ***
LAYER
TYPE POLYGON
CONNECTION "user=postgres password=xxxx dbname=dcmms host=localhost
port=5432"
CONNECTIONTYPE POSTGIS
DATA "the_geom from county"
END
LAYER
TYPE POINT
port=5432"
DATA "the_geom from netbts"
END
*** The PostGis-Table includes an indexed oid. ***
*** Configuration: ***
- php4.3.11 (cgi-mode)
- mapserver-4.4.2-win32-php4.3.11.zip
- postgresql-8.0.2.zip
- postgis-setup-1.0.0-1.exe
When using the original Shape Files (DATA "county.shp" and DATA
"netbts.shp")
as the Layer-Data instead, everything works.
Also, when using either queryByPoint or queryByRect, everything works.
Any help would be most appreciated.
Uwe
