Minfeaturesize??
Sean Gillies
sgillies at FRII.COM
Sat May 7 12:43:39 EDT 2005
Steve,
Yeah, it's for labels only. You'll need an area attribute. In several
apps I've sorted water bodies, parks, etc by area and then use the
maxfeatures directive to render just the first N (ie largest) features
within a map view. Works great. If you have a RDBMS backend, you can
have it order and limit for you.
cheers,
Sean
On May 7, 2005, at 10:34 AM, Stephen Woodbridge wrote:
> I still haven't not figure out a way to solve this issue. What are
> other
> people doing about this?
> -Steve
>> Hi all,
>> I thought there was a way to suppress features from being drawn with
>> MINFEATURESIZE, but it only seems to work for labels. Am I missing
>> something?
>> I have a layer with water polygons and they are getting displayed as
>> single pixels and I would like to suppress them. Is there an easy way
>> to
>> do this short of adding an area attribute and filtering based on that?
>> Thanks,
>> -Steve
Sean Gillies
sgillies at frii dot com
http://zcologia.com
