Changing the imagepath in PHP?
Bart van den Eijnden
bartvde at XS4ALL.NL
Sun May 8 11:48:07 EDT 2005
Bob,
you need to use the set function to change attributes:
$map->web->set("imagepath", "C:/Apache/htdocs/Mpages/MuralMaps/");
$map->web->set("imageurl", "/Mpages/MuralMaps/");
Best regards,
Bart
On Sun, 08 May 2005 17:41:59 +0200, Bob Bruce <covariance at SHAW.CA> wrote:
> Is is possible to have the map images redirected by changing the
> imagepath
> and imageurl ? And is it possible to do this in Windows?
> In my web page I have the following lines:
> $map->web->imagepath = "C:/Apache/htdocs/Mpages/MuralMaps/";
> $map->web->imageurl = "/Mpages/MuralMaps/";
> In my .map file I have the following lines:
> WEB
> IMAGEPATH "c:/Apache/htdocs/temp/"
> IMAGEURL "/temp/"
> MAXSCALE 228000
> MINSCALE 200
> END
> after running the php code the image stays in the location named in the
> .map
> file and doesn't get redirected to the location set in the php code.
> I am running PHP 4.3.11 and PHP MapScript version 4.5 on Windows 2000
> PRO.
> Am I doing something wrong?
> thanks,
> Bob Bruce, Winnipeg, Manitoba
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
