dealing with mixed geometry datasets
Frank Rittinger gis at SCHNEGG.NET
Mon May 9 10:21:10 EDT 2005
Hello Bart,
Bart van den Eijnden wrote:
> Hi list,
> does anybody have some best practices for dealing with mixed geometry datasets within Mapserver?
> For instance Mapinfo files which contain both points and polygons.
> Is it possible to do an OGR query based on geometry type and use 2 layers in the MAP file?
that´s what we do: add a column in Mapinfo with the geometry type,
define two layers (or more, depending on the number of geometry types)
in the mapfile and use a filteritem to distinguish between the different
geometry types.
Best regards,   Frank
Frank Rittinger
TERRAPLAN Geographische Informationssysteme
Gewerbestr. 33
79227 Schallstadt
Germany
Tel.: 07664-505315
Fax.: 07664-505321
http://www.terraplan.com
