getShape w/ OGR and MapInfo Tabs
Stephan Holl
holl at GDF-HANNOVER.DE
Mon May 9 14:49:32 EDT 2005
Hello Frank,
thanks for looking into this.
On Mon, 9 May 2005 11:20:04 -0400 Frank Warmerdam
<fwarmerdam at gmail.com> wrote:
> I looked through mapogr.cpp and there is no obvios reasons
> why shapeObj's read through OGR would not have their
> bounds set properly. When you say that the extents
> are set fine with shapefiles or PostGIS do you mean accessing
> the shapefiles or PostGIS through OGR or using the direct support
> for these types in MapServer?
No. I think I am using direct connections for both PostGIS and shape. I
will try if using an OGR-Shape-Connection will give correct shapeObj-
>bounds.
If not, I come back to you and probably fill a bug report.
> I would suggest that you submit a bug report via bugzilla
> including the a sample data file, and a minimal script demonstrating
> your problem.
Best
Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office (TCH) - Vahrenwalder Straße 7 - D-30165 Hannover
Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
Phone : ++49-(0)511-9357560 - Fax: ++49-(0)511-9357100
