itemquery
Lluís Garcia i Mestres
lluisgm at GMAIL.COM
Mon May 9 15:43:55 EDT 2005
Hi list,
I'm trying to implement the itemquery option shown in mapserver test
suite. As I could read in old messages, the filter option isn't needed
anymore and now requires the qlayer, qitem and qstring.
I can display the item query also with a query map, but my problem is
to adjust the qstring in order to select the item from a text list. I
can just display the item query if I write the exact item that I want
in the qstring.
This is the html from where I want to launch the itemquery. As you see
I must specify in the qstring the item, how can I get the item from
the text options?
<SCRIPT language=javascript>
var parcela = new Array('00001','00002','00011','09001','09006');
function write_parcela() {
var i;
for(i=0; i<parcela.length; i++)
document.write("<option> " + parcela[i] + "\n");
</SCRIPT>
<BODY bgcolor=#e2deae>
<body bgcolor="#e2deae">
<font size="+2" face="arial,helvetica"><b>Item
query</b></font><b><font size="3"
face="arial"> >>> Arees de les
parcel·les </font></b>
<p>
<BR>
<FORM name=test action=/cgi-bin/mapserv>
<INPUT type=hidden
value=/var/www/html/mapserver/dades/santguim/map-script/santguim-java-itemquery.map
name=map>
<INPUT type=hidden value="363469 4.60971e+06 371839 4.61674e+06" name=imgext>
<INPUT type=hidden value=itemquery name=mode>
<INPUT type=hidden value=/cgi-bin/mapserv name=program>
<input type="hidden" name="qlayer" value="parcela">
<input type="hidden" name="qitem" value="PARCELA">
<input type="hidden" name="qstring" value="09001">
<font size="3" face="arial">Selecciona una parcel·la:</font>
<SELECT size=1 name=name>
<SCRIPT language=javascript>write_parcela()</SCRIPT>
</SELECT> <INPUT type=submit value=Go!>
</FORM></P></BODY></HTML>
My map file is
# Característiques map
NAME colza
STATUS ON
SIZE 500 400
SYMBOLSET /var/www/html/mapserver/dades/santguim/map-script/marker.sym
EXTENT 363469 4.60971e+06 371839 4.61674e+06
UNITS meters
IMAGECOLOR 219 238 238
IMAGETYPE png
# Inici web
WEB
IMAGEPATH /var/www/html/mapserver/tmp/
IMAGEURL "/mapserver/tmp/"
END
# Mapa per a consultes
QUERYMAP
COLOR 255 255 0
SIZE 500 400
STATUS ON
STYLE HILITE
END
# Capes vectorials
LAYER
NAME parcela
TYPE POLYGON
STATUS DEFAULT
DATA /var/www/html/mapserver/dades/santguim/shp/parcela.shp
CLASS
COLOR 212 212 212
OUTLINECOLOR 0 0 0
TEMPLATE /var/www/html/mapserver/dades/santguim/templates/parcela-itemquery.html
END
END
END
The attribute template is
<td><img border="2"
src="http://localhost/cgi-bin/mapserv?map=/var/www/html/mapserver/dades/santguim/map-script/santguim-java-itemquery.map&mode=itemquerymap&name=[name_esc]&mapext=shapes&qlayer=parcela&qitem=PARCELA&qstring=[qstring]"
height="400" width="500"></td>
<TD><img border="2" src="[img]" alt="query map" align="middle"></TD>
</tr>
Thanks
Lluís
