Rebol mapserver client
Janeks Kamerovskis janeks.kamerovskis at SILVA.LV
Tue May 10 02:15:42 EDT 2005
Rebol (www.rebol.com) or to be more exact Rebol/View is very suitable for
making Mapserver client apps, also available as IE browser plugin.
I wrote an example in Rebol that uses tutorial example data from:
http://terrasip.gis.umn.edu/cgi-bin/mapserv40?map=/data/projects/tutorial/ex
ample2-1.map&mode=browse
Example in plugin mode could be found at:
http://www.rebol.org/cgi-bin/cgiwrap/rebol/run-plugin.r?script-name=cl4mapse
rv.r
Or downloaded from:
http://www.rebol.org/cgi-bin/cgiwrap/rebol/download-a-script.r?script-name=c
l4mapserv.r
This way is more suitable for those, that have no Win IE, but then you
should download Rebol/View (avalable for many platforms) - to run script.
Also a question:
Did I understand right, that in case when mapext variable and also image map
coordinates is calculated at the client side, than to get accurate image map
coordinates client should take care about maintaining the same proportions
between image size and mapext size?
brgds
Janeks
