Python MapScript module cannot be found?
Emil Zegers
taatuut at PLANET.NL
Tue May 10 09:48:45 EDT 2005
Hello Sean,
I tried that by renaming/moving the wrong version NCS dll's that were in the
path.
But I don't know what set of NCS dll's should be used with the Python
MapScript binaries I downloaded...
I tried several (the NCS dll's found on Howard's site, the dll's that come
with MapServer binaries) but so far no luck.
Is there a way to determine what version is needed?
Regards,
Emil
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Sean Gillies
Sent: dinsdag 10 mei 2005 15:34
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Python MapScript module cannot be
found?
Emil,
I think Bas is right. Once you get the outdated DLLs out of your
system directory (or path) the _mapscript module should load properly.
cheers,
Sean
