Minfeaturesize??
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue May 10 13:34:08 EDT 2005
Steve,
That would be really great to have in 4.6. I am also thinking about
adding an area attribute to my tiger2shape translator or a utility to
compute the area from a shape and add it to the attributes. But I think
having this feature makes it much friendlier for people that don't have
the attribute column to start with to get a better looking map.
Thank you for your support,
-Steve W.
Steve Lime wrote:
> Note that you can use the sortshp utility in MapServer to order
> features
> by size assuming you have an attribute that stores area. This is a bit
> more
> high performance than the MINFEATURESIZE approach since not all
> features
> need be processed. I do like the idea though and would like to get in
> place
> by the 4.6 release...
> Steve
>>>>Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> 5/7/2005 1:30:55 PM
> Ok, I have opened an enhancement request to add this to mapserver.
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1340
> Thanks,
> -Steve
> Sean Gillies wrote:
>>Steve,
>>Yeah, it's for labels only. You'll need an area attribute. In
> several
>>apps I've sorted water bodies, parks, etc by area and then use the
>>maxfeatures directive to render just the first N (ie largest)
> features
>>within a map view. Works great. If you have a RDBMS backend, you
> can
>>have it order and limit for you.
>>cheers,
>>Sean
>>On May 7, 2005, at 10:34 AM, Stephen Woodbridge wrote:
>>>I still haven't not figure out a way to solve this issue. What are
>>>other
>>>people doing about this?
>>>-Steve
>>>>Hi all,
>>>>I thought there was a way to suppress features from being drawn
> with
>>>>MINFEATURESIZE, but it only seems to work for labels. Am I missing
>>>>something?
>>>>I have a layer with water polygons and they are getting displayed
> as
>>>>single pixels and I would like to suppress them. Is there an easy
> way
>>>>to
>>>>do this short of adding an area attribute and filtering based on
> that?
>>>>Thanks,
>>>> -Steve
>>Sean Gillies
>>sgillies at frii dot com
>>http://zcologia.com
