GIF Raster Image Process Problem {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Tue May 10 17:02:22 EDT 2005
Dear Akio,
I do not know any free tool to do the task direcly. Recently I have faced
to the same trouble. The name of the raster files contained a row and
a column number. I wrote a simple program to do the task, I attache the c source.
An other possible solution to draw the border of the images in a
polygon shape file, add the name of the corresponding raster file as an
attribute to the polygon and write a "simple program" using shapelib ...
I hope it helps you
Zoltan
On Tue, 10 May 2005, Akio Neuchi wrote:
> Dear Zoltan,
> Thanks for your tips.
> Now I am facing another problem.
> Tile indexing various gif images -- around 800 per district ( in Japan there
> are around 10 districts in sum),
> to a single shp using GDALtindex.
> Though I am thinking for writing a program to generate the same number of
> world files,
> it would be very helpful if there is a free program to do the job.
> Do you have any idea?
> Thanks again,
> Akio
> -----Original Message-----
> From: Siki Zoltan [mailto:siki at agt.bme.hu]
> Sent: Friday, May 06, 2005 8:27 PM
> To: Akio Neuchi
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: RE: [UMN_MAPSERVER-USERS] GIF Raster Image Process Problem
> {Scanned}
> Dear Akio,
> The formula looks like:
> X = Ax + By + C and Y = Dx + Ey + F (Affine transformation)
> The order of the parameters in the world file is:
> A
> D
> B
> E
> C
> F
> The process to find out the values of the parameters is called
> georeferencing. There are a loft of programs what can solve the task
> specifying point on the raster and giving the real co-ordinates for them.
> Unfortunatelly I use commercial software for this purpose, but I think
> GRASS can do it.
> Usually more then the minimal 3 points are used with a least squares
> estimation.
> I hope it helps you
> Zoltan
> On Fri, 6 May 2005, Akio Neuchi wrote:
> > Dear Zoltană?
> > Sorry for my late reply.
> > We were in long holidays here in Japan.
> > Thank you for your recommendations.
> > In fact, by adjusting World file, the Raster/Vector Images finally so-so
> well superimposed,
> > except the coordinates of these images are a bit dislocated, depend on the
> 1st and 4th pixel values on the World file.
> > Though I am adjusting manually those numbers, what is the right formula to
> get the X and Y pixel dimensions?
> > Thanks again for your help.
> > Akio
> > <World file>
> > 0.000038
> > 0.0000000000
> > 0.0000000000
> > -0.000038
> > 139.738114
> > 35.691990000000004
> > MAP #file
> > NAME rastest
> > STATUS ON
> > SIZE 600 700
> > EXTENT 139.5 35.5 140 36
> > UNITS dd
> > SHAPEPATH "data"
> > FONTSET "./fonts/fonts.lst"
> > IMAGECOLOR 225 240 200
> > IMAGETYPE GIF
> > # Projection definition, set-upped by PROJ.4 parameters
> > PROJECTION
> > # "init=epsg:26915"
> > "proj=latlong"
> > END
> > # Web interface definition (including WMS enabling metadata)
> > WEB
> > EMPTY "/gistest/empty.html"
> > HEADER decide_route_header.html
> > TEMPLATE decide_route.html
> > FOOTER decide_route_footer.html
> > MINSCALE 0
> > MAXSCALE 300000000
> > IMAGEPATH
> /var/opt/SUNWappserver7/domains/domain1/server1/docroot/gistest/tmp
> > IMAGEURL /gistest/tmp
> > LOG
> /var/opt/SUNWappserver7/domains/domain1/server1/docroot/gistest/rastest.log
> > # TEMPLATE "decide_route.html"
> > METADATA
> > WMS_TITLE "MapDisplay Demo"
> > WMS_ABSTRACT "Created by AN"
> > WMS_ACCESSCONSTRAINTS none
> > END
> > END
> > QUERYMAP
> > SIZE 200 200
> > STATUS ON
> > STYLE HILITE
> > COLOR 255 0 0
> > END
> > OUTPUTFORMAT
> > NAME gif
> > MIMETYPE "image/gif"
> > DRIVER "GD/GIF"
> > EXTENSION "gif"
> > # IMAGEMODE RGB
> > IMAGEMODE PC256
> > TRANSPARENT FALSE
> > # TRANSPARENT TRUE
> > # FORMATOPTION "INTERLACE=OFF"
> > END
> > ### RASTER Layer
> > LAYER
> > NAME "RAS365313"
> > GROUP "B_RASTER"
> > TYPE RASTER
> > DATA "MS12000DEF365313.gif"
> > # STATUS ON
> > STATUS DEFAULT
> > TRANSPARENCY 100
> > # OFFSITE 125 135 148
> > PROJECTION
> > "proj=latlong"
> > # "init=epsg:26915"
> > END
> > PROCESSING "LOAD_WHOLE_IMAGE=TRUE"
> > END
> > # here starts Vector Layers
> > # background - Parks
> > LAYER
> > NAME "BARA_PARK_AREA"
> > GROUP "BARA_PARK"
> > TILEINDEX "v_bak_ara_park"
> > STATUS ON
> > MAXSCALE 200000
> > TYPE POLYGON
> > PROJECTION
> > # "init=epsg:26915"
> > "proj=latlong"
> > END
> > CLASS
> > BACKGROUNDCOLOR 0 220 0
> > COLOR 150 200 100
> > # COLOR 154 205 50
> > END
> > END
> > # background - Sea surface
> > LAYER
> > NAME "BARA_SEA"
> > TILEINDEX "v_bak_ara_sea"
> > STATUS default
> > TYPE POLYGON
> > PROJECTION
> > # "init=epsg:26915"
> > "proj=latlong"
> > END
> > CLASS
> > BACKGROUNDCOLOR 0 255 255
> > COLOR 100 149 237
> > END
> > END
> > # background - Rivers
> > LAYER
> > NAME "BLIN_RIVER"
> > TILEINDEX "v_bak_lin_river"
> > STATUS default
> > MAXSCALE 200000
> > TYPE LINE
> > PROJECTION
> > # "init=epsg:26915"
> > "proj=latlong"
> > END
> > CLASS
> > COLOR 100 149 237
> > END
> > END
> > END # Map File
> > Sent: Friday, April 29, 2005 5:31 PM
> > To: Akio Neuchi
> > Subject: Re: [UMN_MAPSERVER-USERS] GIF Raster Image Process Problem
> {Scanned}
> > Dear Akio,
> > You should define EXTENT, UNITS and SHAPEPATH at separate lines.
> > Do you have world file to your image? Check the extents.
> > Try STATUS DEFAULT.
> > Bye Zoltan
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <ctype.h>
char *strup (char *str) {
char *p = str;
while (*p) *p++ = (char) toupper(*p);
return str;
int main (int argc, char *argv[]) {
// create world files
int i, row, col;
long x, y;
FILE *fp;
char name[100], oname[10], ext[4];
char *p, *q;
double width, height;
if (argc < 4) {
fprintf (stderr, "usage: tfw width height files\n");
fprintf (stderr, " width - image width in pixels\n");
fprintf (stderr, " height - image height in pixels\n");
fprintf (stderr, " files - name/pattern of one or more files\n");
return -1;
/* sizes */
width = 750.0 / atof (argv[1]); // replace the real width 750
height = 500.0 / atof (argv[2]); // replace the real height 500
for (i = 3; i < argc; i++) {
strcpy (name, argv[i]);
fprintf (stderr, "%s\n", name);
p = &(name[strlen(name)-4]);
strup (p);
if (strcmp (p, ".TIF") && strcmp (p, ".JPG") && strcmp (p, ".GIF") &&
strcmp (p, ".PCX") && strcmp (p, ".BMP") && strcmp (p, ".TGA") &&
strcmp (p, ".BIL")) {
fprintf (stderr, "unsupported raster format: %s\n", name);
continue;
} else {
q = &(name[strlen(name)-8]);
strncpy(oname, q, 4);
oname[4] = '\0';
if (strcmp (p, ".TIF") == 0) strcat (oname, ".tfw");
else if (strcmp (p, ".JPG") == 0) strcat (oname, ".jgw");
else if (strcmp (p, ".GIF") == 0) strcat (oname, ".gfw");
else if (strcmp (p, ".PCX") == 0) strcat (oname, ".pxw");
else if (strcmp (p, ".BMP") == 0) strcat (oname, ".bpw");
else if (strcmp (p, ".BIL") == 0) strcat (oname, ".blw");
else exit (-1);
fp = fopen (oname, "wt");
// calculating coordinates from row and column number
row = (q[0] - '0') *10 + (q[1] - '0') - 44;
col = (q[2] - '0') *10 + (q[3] - '0') - 24;
x = 642750L + (long) col * 750L; // change the constants!
y = 233500L - (long) row * 500L;
fprintf (fp, "%.8lf\n", width);
fprintf (fp, "0.0\n");
fprintf (fp, "%.8lf\n", height);
fprintf (fp, "%ld\n", x);
fprintf (fp, "%ld\n", y-500L);
fclose (fp);
return 0;
